- Bill
- Jul 15, 2020
- 31
- 3,048
- 4,992
- Portland, OR & Eureka, MT
- 2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
- Wildtrak
You will likely have your work cut out on the oil pan. On the Raptor to change the pan the front axle needs to be dropped/lowered. Guessing that the Bronco will have similar issues. On the Raptor it is not a straight swap. The pick up tube also needs to swap. Make sure your pick up to pan clearance is correct.I’m having trouble finding one that says it will work for the 10R60. Does anyone know any companies that make an aftermarket pan that will work for the automatic transmission on the Bronco? Of the first things I’m doing when I take delivery will definitely be to replace the plastic oil and transmission pans with aluminum ones.
