Aftermarket Transmission Pan for 10R60
  • Thread starter Deleted member 18651
  • Start date
  • Watchers 6
Guest
I’m having trouble finding one that says it will work for the 10R60. Does anyone know any companies that make an aftermarket pan that will work for the automatic transmission on the Bronco? Of the first things I’m doing when I take delivery will definitely be to replace the plastic oil and transmission pans with aluminum ones.
Raptor.Tremor.Bronco
Miami, FL
2021 Bronco Wildtrak, 2014 Raptor, 2020 Tremor
What is a 10r60? I've never heard of it. My f150 has a 10r80 and my superduty has a 10r140. Is it a weaker trans that's in the bronco?
2Jeeps&PatriotX1
Denver, CO
Thats what skid plates are for.
da_jokker
Jeep Wrangler JKUR
So the Bronco isn't getting the beafiest transmission?
If we aren't getting the F150 are we getting the Ranger version?
bytheway
Brice
Louisville, KY
Why the hell does the ranger get a better transmission than the Bronco?
Thed
Ben
Raleigh, NC
  • Like
Reactions: abe
Hopeless Diamond
JR
Chumstick, WA
F350/2dr Rubicon/'96 4R/'75 Intl D150/'22 Badlands
The Bronco isn't meant to be hauling loads like a truck would, and as well documented here, nor tow as much. That maybe one of the items contributing to a lower tow rating too.
bytheway
Brice
Louisville, KY
They used a transmission rated for 442 ft/lbs behind an engine making 415 ft/lbs? That was part of the reason I skipped the 7MT because it was only rated to 400 ft/lbs I believe.
HoosierDaddy
Indiana
Because truck stuff.
Truck people do truck stuff.
SUV people crawl the malls.
You don't need no 10r80 to hop a curb with one tire!!!!
True Offroaders ordered the manual 2 door.
(complete and total :poop: post)
babraunagel
Golden, Colorado
Toyota FJ Cruiser
The 550 manual tranny stands for its torque capacity in newton-meters, which equates to 406 lb-ft, although the company says that limit can go all the way up to 590 lb-ft, depending on application.
NachoMama
TIm
F-150
Felix808
SRV CA
Keep an eye out for a trans pan here or better yet, call and ask/request if they can design and build one for the 10R60. I'm sure you're not the only one who would like one.
https://yourcovers.com/transmission...set=0&Offset=0&Per_Page=12&Sort_By=disp_order
I reached out to them this weekend & got this reply this morning.
"Hi xxx-
We do not have any info yet on the new 10R60 transmission. It's just
too new. It would be nice if the 10R60 and 10R80 use the same
transmission pan like with the 6 speed Ford transmissions, 6R60 and
6R80. We just don't know yet. We hope to get more information on the
2021 Bronco in a few months.
Thank you for your interest in PML's products -
Valerie "
Bronco2021RV
Robert
Prescott Valley Az
Acura rdx
Plastic cracks too. I’ve seen QC issues involving cracked pans at KCAP on the F-150 pans from too much torque (originally the spec).
Like I said it’s just a personal preference to have the extra cooling capacity regardless.
I’m sure aftermarket will have some options and trans coolers . Same thing for the diff cover. My big concern is going to be keeping that 10r60 cool 😎
Tomcat2
CO
'71 ol blu, '21 new blu
