A-pillar trim help
skyhunter
MA
2024 2DR Bronco
So I found an attachment on the forum showing the trim removal process, somewhat. It is only step two. I need to remove the sections between the A-pillars and the overhead console.
It states "refer to A-Pilar Trim Panel - 3-Door (501-05 Interior Trim and Ornamentation, Removal and Installation)" but I can't find this document. I don't want to go digging around a panel cover with an air bag under it.
Anyone have a copy or have done this procedure?
Charlie Mike
Louis
Ford Bronco
This might help you.
My Bronco didn't come with the upfitter switches. I bought them from Middleton Motorsports and used there video to install them myself.
It isn't bad at all.
rugedraw
Javier
Miami, FL
2021 Ford F150 Platinum FX4 EB/2023 Bronco Sport Badlands/1991 Mustang 5.0 coupe
Attached is the enitre document for the a-pillar removal in the workshop manual for a 2024 3-door Bronco.
Charlie Mike
Louis
Ford Bronco
Ok, getting the sun visors back in was an absolute PITA! I forgot to mention that, lol.
skyhunter
skyhunter
MA
2024 2DR Bronco
Thanks, do you know what the "pyrotechnic" precautions are?
skyhunter
skyhunter
MA
2024 2DR Bronco
Thanks. That was fast. I am actually just making two panels to go under the weather strip for the roof panel to keep the leading edge of the canvas top from popping up on the road. But the bolts on the weather strip have nuts on the bottom rather than going into treaded bosses. They really want to rack up the billable hours I guess.
rugedraw
Javier
Miami, FL
I don't think you need to worry about those things, but here you go:
23OBX2.7
AB Canada
2023 Bronco
Its not easy the hyper exotic car shop I use messed up the trim when installing the camera and radar hardwire in there. There is a simple trick for sunvisors but a pita untill discover the move haha....same in Mustang.
KABQ
Aaron
Albuquerque, NM
I can only assume it's airbags, unless you've made some pretty serious enemies
skyhunter
skyhunter
MA
2024 2DR Bronco
I know what the precautions were for, I was wonder what the precautions were. All set now.
