BigMeatsBronco
Allan
2021 FE 2 door
So after 60k miles my rear axle is junk.
While cruising at high speeds, the rear end started making noises, and once I stopped checked for leaks and or loose Pinon, it began to make the dreaded skip-a- broken-tooth-clunk-sound🫨
I removed the rear driveshaft ( out of precaution to the rest of the drivetrain) and limped home in 4H front wheel drive.
durring removal I was surprised to find the outter diff cover bolts had become looss🤔...after disassembley, I found what I had suspected, the 40s, 5.38 ratio, towing, and heavynlead foot are just TOO much for a OEM m220.
the case flexed under heavy loads enough to cause gear deflection....the ring gear moved away from the Pinon and overloaded the side case bearing causing it to spin the race. thos damaged the inside of the housing and caused slop in the ring gear (the ring gear and diff moves side to side nearly a 1/4" now) Obviously this much deflection cause the contact patch to run way nean the edge of the tooth and broke several off under acceleration.
while removing the parts I also discovered that BOTH the axle bearing races had also spun in the housing!!! I believe this was caused by tall tire leverage or bending moment under acceleration while side loaded. (hard corner G forces)
I feel the OEM axle is plenty strong (especially the shafts) for tires up 38"....beyond that the limits are found quickly. I have also confirmed this with mechanics, at 4x4 repair centers, that see M220s in Jeeps consistently with the exact same issues.
Ford Bronco Toasted my rear M220 axle...40s, towing, heavy foot 😋 IMG_20240131_105058
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
How heavy was the trailer?
Sounds like your proposing an overall failure due to housing flex. So the fix is to weld the axle tubes in and a brace. That should help the center section survive longer. Next would be some bigger wheel bearings to help transfer rotational forces to the axle housing vs the carrier bearings. So a bigger axle!
I think this is interesting since jeep is transitioning to a full floating rear axle. That would solve some of the stress issues your describing.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
interesting.
i wonder if that's part of the reason 74Weld's portal upgrade includes switchover to full floating rear axle
huey
kevin
Ontario & Kentucky
VW GTI VW EOS GMC Envoy Badlands Bronco
ooofff!
that's narly!!
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
5000 lbs
I also towed my 40,000 lbs peterbilt out one time as well. ...smoking all 4s on dry pavement.
absolutely correct, my gearhead mechanic buddy that does ring and pinion for a living, assured me this is the main issue the cast center section is NOT very stiff and flexes under load and twists also. he's seen the cases spread so far apart the housing is junk on many occasions. this is why the HD cover is important with studs instead of bolts. it adds alot of rigidity to the weak case. Also the case stretches enough to loosen the cover bolts in my case.
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
interesting.
likely, and Im sure that helps at the wheel ends, but the extra leverage the portals add to the housing and center section worries me. a HD truss brace would help alot, but I think the m220 is at its limits with 350hp and low gearing and big tires, portals or not.
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
Bummer for sure. Are you going to go to the Dana 60 semi float that I’ve seen offered?
5GENIDN
Joe
Idaho
You may well be right.....
CarbonSteel
Colorado Springs
2023 Carbonized Gray
This was caused by housing deflection due to the large tires that do not lose traction. When it twists, the distance between the ring gear and pinion is increased and the lack of engagement causes the teeth to break/shear.
Dusty
Mentone, CA
70, 71 & '21 Broncos
interesting.
No, the portals require floating rear axles because that's how they engage into the portals (splined shaft into splined gear). A semi-float axle simply isn't compatible. Any benefit the full floating axle imparts to the assembly, vis-a-vis the forces BMB is talking about here, is simply coincidental, but welcome.
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
And why do we think it’s necessary to use 40s? Just saying… Thank you for sharing your experience.. We are forewarned and well “armed”. 🤓
because I like em and I drive on logging roads and skidder trails for work.
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
absolutely correct, spicers engineer said "the deflection and a shockload will do this every time with a lead foot"
probably like when I haze the tires over the train tracks....lol
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
