7MT - 3rd gear notchiness?
thesocalexplorer
Southern California
Hey fellow 7MT owners. I'm about 5500 miles into my 7MT ownership. Wanted to see if anyone else is noticing 3rd gear to be a bit more notchy than the other gears? Almost like some extra force is needed to get into the shift gate, and then it finally clicks in.
Mainly happens when the rig is under full operating temp, happens way less when up to temp. All other gears are super smooth.
Anyone else experiencing 3rd gear notchiness?
Jawaburger
Champaign, IL
2022 Bronco, 2 Door, Manual, Cactus Gray
I have no issues with different gears, all gear shifts are smooth.
5.0 to 2.3
All mine are smooth and sexy
dejones64
Dan
MN
Bronco 2-dr Black Diamond
I'm at about 5,500, all good so far.
Direwild
Tuscaloosa Alabama
2022 2dr Base Bronco
I think I know what you are talking about. I've had a manual since 2013. First a 2012 Mazdaspeed 3(I miss you baby), then a 2016 golf GTI, and now a 2022 Ford bronco. Everyone of them had a bit of a hiccup with 3rd gear. Idk why but it never behaves like the other for some reason. Even in the bronco I've missed 3rd gear once already. But if it's very noticable I'd take it in for warranty work.
cyberfalco
Tony
Conway, AR
2011 JK, 2000 Ram 2500, 1993 FZJ80, 1994 FZJ80
Does anyone have the gear ratios for each gear? Typically the jump from 2nd to 3rd is the largest jump on a lot of manuals which can feel odd at times.
bradcd
Brad
Saab 9-3
I have about 800 miles so far on my Badlands. While I don't notice anything specific about 3rd gear, I do feel it helps to release the clutch more slowly while accelerating into 1st, 2nd, and 3rd. Once I hit 4th and above I can get my foot off the clutch as humanly possible.
Ford Bronco 7MT - 3rd gear notchiness? ratios
Lil Red Broncette
Explorer
I've had a manual trans vehicle most of my life and never experienced anything particular about 3rd.
Lil Red Broncette
Explorer
Haven't gotten my Bronco with the Manual Trans yet.
in general, what you describe sounds like the resistance the synchro will generate when there is a big mismatch between the engine shaft RPM and the RPM of the gear it is trying to synchronize with. This is most commonly experienced when down shifting to the lowest gear where engine RPMs are low and actual RPM if it were in the lowest gear would be very high.
I wonder if what you experience gets better or worse if you shift earlier than typical and or wind it out to higher RPM before shifting.
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
My F350 was worse, my Bronco had some. In time the gears mesh together and get smoother. I’d be worried if it gets worse.
Direwild
Tuscaloosa Alabama
Honestly it could be the way I drive but I usually stay consistent with my shifts. Bronco is not bad about it. Now my Mazdaspeed 3 it probably happened to me at least once every 2 months. The GTI was better about it but every now and then I'd miss shift into 3rd.
Btw it's only 3rd that this has ever happened to me. No other gears has ever cause me to miss shift.
thesocalexplorer
thesocalexplorer
Southern California
That's a good point! I usually notice it right at 3k rpm. A bit lower or higher (2.7 kor 3.2k) and the shift is back to buttery smooth. May just be a quirk of the getrag.
Clutch in at a stop, rowing through the gears is buttery smooth.
DaveInSA
Seguin, Texas
2025 F150 Lightning Flash
Mine has it, conditionally. I haven't determined what those conditions are. Match up between engine and gear speeds maybe. Sometimes it's smooth, sometimes there's a little hitch going in to 3rd. But it's never that bad.
SoDak1623
Cole
South Dakota
1996 F150, 2022 Badlands MT
8700 miles into mine since April and no complaints about the transmission. It is smooth and direct for all shifts. I had a 2013 focus with the old ford MTX-75 5 speed and a 2004 focus with the same MTX-75 after that up until the Bronco and never had any issues with Ford manuals. I hated the 6 speed in my 2015 Jeep Rubicon though. It never shifted well, popped out of 1st occasionally, and the ratios were just bad. But no issues with my Ford transmissions.
Bronco-ocnorB
Luke
DFW
Ford Flex
I have had some notchiness going into 2nd gear from day one....today (just hit 1,000 miles), while hitting some traffic on the highway I was downshifting through the gears, get to second and it would not go into gear, almost felt like trying to get over into crawl without lifting the collar. Kept the clutch in and tried to cycle through first and back to second to try and sync it up (keeping the clutch in) and it would not go into first either. Felt the same way.
Took a deep frustrated breath and cycled over into third and back to second and was able to 'force it' in. When I got off the highway on my exit, at a light cycled through all of the gears several times. It was fine accelerating through, but when downshifting again it did it again....
Anyone experience the same? Any thoughts?
