2.3L 7MT — lurching/stuttering in low gears between 2-3k RPM
bronco100
Colorado Springs
Ford Bronco 2022 2dr
Alright I've had my Hill Assist feature turned off since Nov 3rd and am happy to report the unexplained bucking I was experiencing in low gears/cold engine has completely gone away. It's worth a try to disable the Hill Assist for anyone that's experiencing this. There is some understandable bouncing in throttle sometimes when starting from stop on a steeper incline but I attribute that to just the full weight of the vehicle against the clutch and finesse of accelerator pedal.
Gonna try this, as I also have this exact bucking issue.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I’ve gone months without it happening…and then it will just come back out of nowhere. I don’t think that’s it. It seems to always be going into 2nd gear.
bradcd
Brad
Indiana
Saab 9-3
I just had this lurch happen again on me, but it has been so infrequent after turning off the hill assist that I can't recall when it happened last. It occurred after the truck had sat for 2 hours, engine temp at 140F, and while accelerating in first. If this only happens once every 3 months I'm fine with it. Just curious, has this issue been reduced for those that have disabled hill assist?
redone17
Cold Spring, NY
I’m 100% certain is has nothing to do with Hill Assist.
Mine still does it once in a while too. Just did it today. Always when warm, but not full temp after I am parked for a few and get back in. First or second gear.
bloominguez
Tom
Atlanta, GA
'22 Br BD, '22 5BW, '95 Integra, '94 VFR, '04 SV
Completely agree. This is very repeatable for me. Go to the gym in the morning, Bronco is parked for about an hour. Stutters when driving away when the temperatures are just right. Engine is "warm". Not fully cool, not up to full temp. Driving on a steady uphill pulling away from a light. Not too often, but always in those same conditions, same exact stretch of road, same cool-ish temperatures outside. Has never happened at any other time or place. This is just shitty mapping by Ford, half-assed work on their part.
djp
djp
Idaho
'22 Badlands 4dr || '21 Bronco Sport BigBend
This has happened twice now, on my 2.3L 7MT badlands 4dr — in first and second gear. I’ll be in gear, slowly climbing through the revs right before I shift around 3.5k or so, and the car will kind of lurch back and forth almost like I’m applying throttle and letting off, over and over. Feels like a yo-yo effect a bit. My foot wasn’t on the clutch pedal whatsoever, but as soon as I press in the clutch to shift, it stops. Has only happened when the car is relatively cold and it’s the first time I’m get up to road speed after starting it.
I only have about 350mi on it so far, so wasn’t sure if this is simply a break-in quirk or not. It does feel like some amount of ECU learning could smooth it out, or possibly a turbo/wastegate/vacuum leak issue? I remember seeing someone else’s thread talking about their clutch acting strange similar to this but couldn’t find it by searching.
This has happened a few times to me as well. About 4 times so far, and i'm at 4k miles. It always seems to happen after i've gone somewhere and parked for an hour or two. When I start it up, and let it warm up for a minute or two, i pull out of the parking lot and in first gear, rev-up to shift, and it goes into the same yo-yo effect, as if i was slamming the gas on and off. The only way to resolve is to push int he clutch and let things settle down and then continue.
I dont know...but maybe turbo lagging when it's not warmed up or ready... i really dont know
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Last time mine did it was last Fall in the Old Faithful parking lot in Yellowstone. You should have seen the look my wife gave me when she asked WTF are you doing? I had to laugh, and hang on. Bucked for a 1/4 mile before it straightened up. Hasn't done it since.
EveryDayBronco
Motorcycle
My bronco is at the dealership right now to figure this out.
Happened twice last sunday which prompted the service appointment and happened once yesterday.
It happened many times actually, I just wasn't worried about it but now with 9,500ish miles on the bronco I figured I better get it looked at.
Did not happen during the test ride by the service guy this morning.
Waiting to hear back from the dealership!
thesocalexplorer
Joe
Southern California
Haha, my wife had the exact same reaction when my bronco started bucking. A quick drop into neutral & back into gear usually solves it for me. Always first or second gear, right around when it hits 2300-2500RPM for the first time.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Mine went months without a buck, last summer perhaps? Coincidentally, I took it in for the sway bar issues, as per the TSB the techs reprogrammed the CHCM…. Now we are back to bucking!?
What the buck!?
As always, during the cold start warm up cycle, first gear down the driveway…. And it’s not even cold out. Again, what the buck!?
And there are no new software updates that I am aware of
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hello there- I can look into this for you. Feel free to send over a private message with your VIN and dealership information at your earliest convenience.
redone17
Cold Spring, NY
It comes and goes. That’s the weirdest part. Sometimes it won’t happen for months. Then it will come back and do it a few times here and there.
DBadlands
Portland Oregon
‘22 Bronco 2 Dr, ‘68 Mercury Cougar, ‘68 F100
Mine has bucked for three straight days now. Each time after it sat for an hour or two after being completely up to operating temp. Each time in second gear.
I already planned to do the Ford Performance tune so hopefully that will take care of the issue.
redone17
Cold Spring, NY
Let us know if it does. Mine has been doing it more often as well. Pretty frustrating.
