74Weld Bronco Portals
Exodus4x4
Bubba
Jeep Gladiator
Looks like 74Weld is a lot closer than previously thought. Can’t wait to get our hands on a set!
GreyZ
Gulf South Louisiana
Interested in seeing some more info.
da_jokker
Jeep Wrangler JKUR
I thought with portals, you basically lose the daily driver aspect becaust the gearing gets so low you can't drive them on the freeway?
As many problems as portals would solve, I don't think I could ever spend that kind of money :(
userdude
Denton, TX
2023 2dr Badsquatch
What are portals, other than doorways to other dimensions? 🤔 🧙‍♂️
Exodus4x4
Exodus4x4
Bubba
Jeep Gladiator
Kinda true. If you re-gear the Bronco to 4.10 ratio in the diffs it’ll calculate to 5.0 as your final drive ratio with the portal. Perfect for 38-40” tires with the 10 speed imho.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
any other mods to the suspension to accommodate the portals?
Exodus4x4
Exodus4x4
Bubba
Jeep Gladiator
Nope. Extended brake lines and as mentioned before, I’d re-gear to keep the rpms more suitable for daily driving. You don’t have to re-gear but I would.
BAUS67
redneck
Central PA
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
I did reach out to Quinn, and he shared a few details: The gearbox units will be the same essentially for all makes. They are 4 gear spur gear design based on their race portals, which obviously have undergone real world durability testing. Jeep and toyota versions are done, Bronco is going through tweaks for the brake hoses/bracketry etc, but he expects them done soon. His intention has always been to "mass market" them (of course this takes time and testing to do right). There will be a version for the D60 semifloat that Dana is selling for 6g. He claims no noise @80mph w/the gears they use
da_jokker
Jeep Wrangler JKUR
Too bad they can't do a 1:1 gear ratio. I guess they assuming people would be putting much larger tires on.
Man I can't imagine going down the freeway at 80 with portals but if that's true.. that's awesome.
chtucker
Kirkland, WA
FJ Cruiser
Badlands 4.46 gears with 37s probably perfect SAS with 4.7 and 37” tires is probably not 80mph friendly.
Bronco2door
UTAH
Bronco 2 door
I believe this Gladiator has 4.10 with a portal is 5.0 final drive.
Merc4x4
steve
Looks like 4.10's are available with the Dana Ultimate Bronco axles.
Defyfate11
Jaime
Clovis, CA
2020 Camry TRD
I have the 4.7 gear ratio in my Bronco, would putting Portals on be to much of a regear to my highway driving experience? I am currently running 37"s. Should one have to regear to put the Bronco back at a final gear ratio that falls within the 4.56-4.88 range?
Exodus4x4
Exodus4x4
Bubba
Jeep Gladiator
You can re-gear if you want but the owner of 74 didn’t and said he does mind it with the 38’s
