74Weld Bronco Portals now available!
What I think about Bronco Portals...
  • Total voters
    504
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
interesting on how 'stock' the suspension was on those 4600 vehicles. very reminiscent of the wild track setup
userdude
userdude
Denton, TX
2023 2dr Badsquatch
He makes it sound like a tuned up WildTrack with portals and J something-or-other. I wonder why the 4600's aren't running the 74Weld rack by now?
BAUS67
redneck
Central PA
They were built using Ultra4 spec Howe racks. No need to be bolt in when you just have Ford bypass all the nannies.
That Atterberry team I posted in your thread tell all about why they did what they did. Note: you might have to go back to last year when they were first building the car, it was Cyper Yellow back then.
Also forgot, I believe that "J-bar" he is talking about is similar to what Rock Krawler is doing.
5GENIDN
Idaho
Holy smokes! WOW.... I have never in my life experienced anything like this....
I was driving the bronco home today. There I am on a 5 lane road and coming up to cross a 5 lane highway... I cross it all the time. It is in good shape, has a few ruts. Always gives you some bumps going over. Hard suspensions you want to slow down and take at 25 to 30.... Speed limit is 40 (the road I am on) (highway is 55) I could see the light was going to change. I accelerated to about 50 entering the intersection just as the light turned yellow. I steeled my self for the ruts/bumps that are always there.... NOTHING.... A push up and then a drop.... Like a just paved 3 foot hill at 50....soft, controlled, like it had just been paved.... I am old, I have driven a lot of cars and trucks.... I have never had anything respond so easily. My wifes Merc is a nice firm but soft ride.... NOT like this.... WOW! I think I am going to be HAPPY!
5GENIDN
Idaho
That actually makes a hell of a lot more sense. as I was trying to figure out the "J" arm....... BUT shouldn't they get more rear articulation then... going from the 5 link to a 4 triangulated?
BAUS67
redneck
Central PA
Yes, I believe that is the reason behind it.
TruckCamper
Peter
Kingman AZ
2023 Bronco 2Dr - 2022 Bronco Raptor
Is the extra portal gearing backlash noticeable? (Gear play between drive and coast)
We had dual tcases on multiple Toyotas and the rock crawling could get a bit jerky going over certain rocks as the gears bounced from drive to coast.
Our Bronco is a manual which will make any gear play more noticeable rock crawling.
5GENIDN
Idaho
I do not have a lot of seat time with them yet but I have not noticed any lash issues with the portal gearing.... Have to admit I have been focused on dialing in my coil overs... But I do think that is something I would have noticed.
Tor148
Tor
Cape May Court House, NJ
23 Braptor Bk, 21 FE RR, 15 F250,
How's the rub on the tires? I need to order and still on the fence.
Went to finish this afternoon and found that I was shorted the banjo bolts for the rear brakes🤬 so order them and will have Monday, of course no one had local. Hope to put her in her tires Monday night or Tuesday at the latest.
Did you get the front end alignment yet?
5GENIDN
Idaho
Yes front end is aligned.... Was pretty close on the guess work but a real alignment made a really nice difference. I have only an road miles so far... only about 80.... I have experienced NO rub other than a small reversing flex that just barley caught the front of my capable bumper in the parking lot of the tire store.
I have a long way to go checking full clearance but I am good on the road. been playing with my coil over settings trying to dial in ride.... The Kings have 28 click points.... I am at 17 front and 12 rear right now and still refining when I get the chance.. (higher number = stiffer)
You caught my "holy smokes" report above? This ride is really impressive.
Tor148
Tor
Ohh yeah I caught that report, gave it some lov!!. It is great to hear, especially because I don't slow down for shit😆😆 Curious to compare with the kings on yours and foxes on mine. Wonder if there will be a difference, but at the same time, how can you compare with all the settings!!! BTW that is A LOT of clicks😆😆
I think I am going to say screw it and order the coopers 40s and see what happens.
5GENIDN
Idaho
All the studying I have done suggest the Foxes are just a bit more refined.... suppose to be pretty close though. I guess each resi has two? adjustments... was not quite clear on that but the fox adjustment allows for a slightly better refinement.
I am still waiting on my procal so I can clear up this chrismas tree. also wonddring if I might have an issue with a wheel speed sensor but I need to get some of this other stuff taken care of so that I can identify.
Tor148
Tor
Yes the foxes have two adjustments a high speed and a low speed.
I have been meaning to ask, what is lit up, and why do you think?
5GENIDN
Idaho
Everything is lit up... it is sensing wheel slippage I think. No ABS No 4 wheel drive....No cruse control.... no emergency brake. I am guessing it has to do with the wheel speed sensors and the regear and tire size.
