74Weld Bronco Portals now available!
What I think about Bronco Portals...
  • Total voters
    503
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
Awww, dude! Those gotta go! Also there's a plastic piece inside the rear of each wheelhouse held on w/3 13mm bolts. Those gotta go too, then try to force the wheelhouse back far enough to get some push pins in the bolt holes, or punch through the wheelhouse w/body bolts and zap them down tight!
BroncoBuckaroo
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
About $19,000 over budget for me, but they are incredible.
Tor148
Tor
Cape May Court House, NJ
23 Braptor Bk, 21 FE RR, 15 F250,
Thanks, i will cut thoses off and try and find the plastic piece you are referring to.
Working on removing the rack and installing the stage 3 rack now.
BAUS67
redneck
Central PA
Here are the directions for JKS kit. Page 5 shows the rear part of the install. Good pics/info to show what to do.
JKS8300.pdf (4x4media.info)
Ford Bronco 74Weld Bronco Portals now available! 1705810903525
Tor148
Tor
Bored
Bored
Texas, USA
'23 BL 2DR 2.3L MT & '23 BL 2DR 2.7L AT
Do you see an issue with fitting the 40's with out body lift and suspension lift?
The fox 2.5 i am planing to not preload, and with the weight I have added i am figuring at most maybe add an 1" if any additional height.
With the nitto 40's I have slight rubbing still with 3" suspension lift, no body lift, on the front of the pinch seam, at full lock with some compression (I plan to actually trim, etc. later as necessary to let me go down 1" of suspension lift). I have a lot of residential streets where turning onto them is like a dip then speedbump. I do have my low speed adjuster at like 5 clicks firmer in the rear and 7 firmer in the front.
Tor148
Tor
Thanks for the info, but that is with out portals, correct?
Tor148
Tor
With portals.
Wow, with 3" suspension lift I would think you would clear no problem.
What rims are you running?
That makes it very interesting that a 38" clears stock as per 74 weld when you are only looking at a 1" difference to a 40" (all things being equal)
5GENIDN
Idaho
SO THERE IS THE RUB!!!! I wondered. That is why 74weld/Quinn recommends 37 to 39s....
Suspension lift should make little to no difference.... full tuck and full droop should be the same (close to it) as the stock suspension. All the suspension lift does is change where in that arc of travel the suspension hits equilibrium.
Now there will be some minor differences between manufacturers.... What is their full compressive length and what is their full droop length. In this case we are concerned about full compressive length.
Now if I remember right... need to check the numbers but I believe Bored, you are running the Kings, No I am thinking Foxes... you have both the high speed and low speed adjusters... that is Fox. I believe Kings have one of the longer compressed lengths. So if the Foxes are rubbing then anything with that compressed length or shorter will rub.... Longer compressed length ???? need to find out.
Razorback
Dallas
Lincoln MKX
Now if I remember right... need to check the numbers but I believe Bored, you are running the Kings, which I believe has one of the longer compressed lengths. That means anything with a shorter compressed length will rub even worse.
So you don't think a mid travel would matter? Long travel would probably be out of the question since it would push the portals even further out... Track wider than an F150.
2bigbronco
Shane
Prunedale ca
2022 bronco
Ok, I just got my 74 weld portals on my 7mt bronco and still have some co.puter bugs to work out.
Anyhow on the wheel topic it turns out badlands wheels ordered without the sasquatch package are 17x8 with 6-3/4 backspacing or +55mm. With some healthy grinding on the upper dual sheer steering mount they will clear the portals.... bairly but work. Im confident that any deeper backspacing wouldnt work unless you jumped to 20s. They also burry the callipers all the way inside the wheel protecting them.
Ford Bronco 74Weld Bronco Portals now available! 20240112_171002
Ford Bronco 74Weld Bronco Portals now available! 20240110_140422
Ford Bronco 74Weld Bronco Portals now available! 20240107_175042
Ford Bronco 74Weld Bronco Portals now available! 20240107_135754
Ford Bronco 74Weld Bronco Portals now available! 20240110_141953
Fishwrinkle
12 GC overland 5.7, 18 GC srt 6.4
I thought the portals were going to keep the half shaft and tie rods closer to stock geo? All I have seen so far appear to max the geo out. What am I missing?
87-Z28
Andy
BMW
Good to know. You get a nice snug fit with lots of positive offset.
