Superchips_Mktg
Jacob
Sanford, FL
www.holley.com
2022 Bronco
This B&M Precision SportShifter for the modern Bronco platform with the 2.3-liter Engine and 7-Speed manual transmission includes a 303 stainless steel stick with an anodized aluminum pivot. Our design reduces the throw by a massive 40% over the factory shifter and provides a shorter more positive feel when shifting gears. To help accomplish this, we increased the stick height by almost 3-inches to create a much more ergonomic shifter position. The factory shifter sits lower than the center console, but ours sits in line with it so you can rest your arm on the console and shift more comfortably. The factory leather shift boot is also retained and attaches to the new black anodized aluminum lockout slider to smoothly and easily actuate reverse. The included black round shift knob shows the shift pattern on top and B&M logos on the sides, both filled in white to tastefully compliment the interior of the Bronco. Also, this shifter has 100% compatibility with the factory knob, so if you want to retain your leather-wrapped knob instead of the B&M knob, you can do so. Finally, the SportShifter attaches directly to the OEM shift cable and includes installation instructions and all hardware necessary for an easy at-home installation.
Features:
  • 303 Stainless Steel Stick and Anodized Aluminum Pivot
  • Reduces Factory Shift Throw by 40 Percent
  • Custom Black Shift Knob with White Accents
  • Improves the Shift Feel over OEM
  • Over 65 Years of B&M Quality
  • Lifetime Limited Warranty
  • Easy Installation
Learn more here: https://www.holley.com/products/dri..._shifters/precision_sportshifter/parts/45209/
Ford Bronco NEW: B&M Precision Manual Sportshifter 752efb47e2734142671e1a402762ce0d84d606a8
Ford Bronco NEW: B&M Precision Manual Sportshifter 6a51bf627a098d04a57833bc79ec82db834e1648
Ford Bronco NEW: B&M Precision Manual Sportshifter e5bcc39cc1d378d8a3c1df55ba4f54b367550da0
Ford Bronco NEW: B&M Precision Manual Sportshifter dad24daa129b000f82857823f164a50a74f7e090
Ford Bronco NEW: B&M Precision Manual Sportshifter eb53a7946281779a4fb6e7b079ddcfcec943d524
Ford Bronco NEW: B&M Precision Manual Sportshifter 344c44512afaf54440be6dfbfac9ca2d67cbb3a1
Ford Bronco NEW: B&M Precision Manual Sportshifter 30ae869f60ac3183353895dd8a3961526b7fd4c1
Ford Bronco NEW: B&M Precision Manual Sportshifter 7cea424c28ef0ff4fba254eaaf346eaefe11aa75
Ford Bronco NEW: B&M Precision Manual Sportshifter 81ca50124f82949e603bb609bc0ee067921f19e8
brtd
Iowa
23' BL, '15 LR4, '22 Beta 390-RS
This looks interesting. I'm not sure if the additional height would be a benefit or not. Have you considered a variety with the standard height?
Blksn955.o
Greg
Wentzville, MO
17 Ford Escape Ti, 94 Ford Mustang GT, 21 BL
wow, that is a long...er....shaft.
I can see it being a little longer but that seems excessive
Tricky Dick
Dick
PNW
www.TD-Distributing.com
That's freaking nice, I want it!
I need to wait until the trans noise issue is resolved though, I don't need them claiming an aftermarket shifter caused it.
heynow14
Nick
Yorba Linda, CA
2022 Bronco - BL SAS MT LUX SOFT
I was interested until I saw that height. The height of factory shifter seems correct and inline for me...adding 3" inches does not seem helpful and would seem to only make for a necessarily longer throw than would have been needed at factory height.
Lèòn
Jersey
Definitely interesting
drive21bronco
North East USA
2021 Bronco Black Diamond
Oh Wow! I think I can word this without it sounding bad.. but I was thinking that having the shift knob higher would be better. Hmm may have to wait until someone here installs it and posts a review.
NorthShoreBronco
Steph
Canada
www.youtube.com
21 Badlands 2D, 22 BD 4 Door
Very nice! I'll have to add that to my never ending list of mods.....
BigHoof
PA
Ram 2500
Wouldn’t the throw be reduced even more if it was factory height? This looks a little too “big rig”.
Wondered the same thing. After viewing the install, it appears as though the cable attach points must be further from the pivot point. Doesn’t seem like there is enough to compensate and make the throw 40% shorter when the lever is 3” higher though. But I guess it is because that’s about all that is different. Housing pivot point is in the same place.
