37s or 35s?
Axel
Axel
Denver
hey all I have a 2022 obx non-sas and am looking to upgrade to some bigger shoes. What would i have to do to fit 37s or 35s? could stock suspension handle the larger tires? would i have to change any gears? Also I would like to avoid removing crash bars.
CitrusBronco
Everglades
Citrus county, FL
Everglades
This has been discussed 100x before. Use the search function and read the many threads.
If you have any follow-up questions we’re all here to help.
Short answer is yes they will fit with a lift, yes you will need to remove crash bars, gearing is a good idea.
PWillette
Parrie
Maine
On the stock OBX +55mm offset wheels you can go up to a 35 x 10.5 w/o a lift and clear the UCAs. Some have gone to 35 x 12.5 but it is extremely close to rubbing the UCAs. Here's my friends OBX (Carb Gray) w/ my non-squatch +55mm wheels on 35 x 10.50s (no lift) next
Ford Bronco 37s or 35s? OBX n BL
to my BL on 37s w/ +2" lift.
Mike leggiero
Ky
green one with a 2 in lift base on 37 also with 35s the blue on a 2.5 lift and 37 and no lift on 35. the 37 are a terramax rt d rate
Ford Bronco 37s or 35s? 1000000873
Ford Bronco 37s or 35s? 1000000804
Ford Bronco 37s or 35s? 1000000658
Ford Bronco 37s or 35s? 1000000661
