35 skinny's?? Sasquatch
23OBX2.7
AB Canada
2023 Bronco
The width cutoff on the +55 offset OEM wheels is around 11" to avoid rubbing. Chris might not experience the rub with his lift and 11.5" width. But the test of rub at full inflation driving on pavement isn't the test, but rather air down and articulating off road. Also, while tires are manufactured to a ratio, they often aren't true to the stated ratio.
A great summary - thanks!
box986
Paul
NNJ/NEPA
23 GX460 22 Sport BB, 03 Caddy EXT PU, 96 Lincoln MarkVIII, 92 Toyota PU 4x4
I am running Toyo 35x11.50s w/1.25" spacers. No rub, even with mud flaps
Preheateddinner
S.
22 Ford Bronco BB 2D
I'm also running Toyo 35x11.5 with mud flaps, but I don't have spacers, I have aftermarket rims with 25 offset. No rub.
Romokid
MA
Wildtrak & JKU
Update, Actually just found MT has Baja Boss AT at 255/85/17 @ 34.6" tall 10.8" wide, but says it is only approved for 8"wheel. I think stock SAS wheels are 8.5? Can anyone confirm?
Yeah the SAS rims are 17x8.5”. I have been running the 255/85-17 MT Baja boss on my JKU mounted on AEV Salts that are 17-x8.5” for 3 years now with a single issue. Funny thing is though that I bought my tires from Quadratec and their spec section list 8.5 max width for them where MT’s website lists 8” max width. I like those tires that I was looking at getting them for the wife’s Wildtrak as they pick up less rocks than the stock SAS tires as we live on a dirt road.
Jason519
Jason
Alabama
F150 4x4
I’ve been running 285/75s Toyo open country a/t 3s on both factory wheels I have I just swap wheels when I get new tires 87k first set last over 60k second set counting
Ford Bronco 35 skinny's?? Sasquatch IMG_6889
Ford Bronco 35 skinny's?? Sasquatch IMG_9811
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
Yes, and one of the reasons I won't be going pizza cutters...
