2dr mount points behind front seats?
brkdncr
Southern California
Toyota 86
When I haul things in the back with the rear seats down I’d like to hook tie down straps into rings so I can keep stuff from shifting around. Are there any mount points behind the front seats for such a purpose?
Roger123
Roger
VA Beach, VA
No, there are no factory mount points behind the front seats. I pulled my rear seats and made a platform like the one above and put several d-rings on it.
davidforlife
Atlanta, GA
BadManSquatch
There are the 3 car seat mounting points on each seat, headrest posts, and, of course, the hardtop bolts. I add soft tie down loops to each one for easier access.
Ford Bronco 2dr mount points behind front seats? IMG_2368
GI_Jo_Nathan
Jonathan
A little confusing, your title says front seats, but your post says rear seats. As far as the rear yes there are four tie-down points in the rear cargo area. You can see them in the post above.
brkdncr
brkdncr
Southern California
Toyota 86
thanks, fixed. I’m looking to hold things down on top of the folded down rear seats. I’m aware of the cargo area rings.
brkdncr
brkdncr
Southern California
Toyota 86
thanks that provides some options but not what I was hoping for.
I had a large box on top of the folded down rear seats last weekend and didn’t have a way to keep it from shifting.
I also put a large cooler there on occasion and use the headrest as a tiedown point to keep it from shifting but it doesn’t work well.
davidforlife
Atlanta, GA
BadManSquatch
Yeah…I agree. Not ideal. Have you considered cargo nets? More coverage and tie down options/angles. Gladiator makes some really nice ones.
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
Maybe you could slip something like this D-ring under the rear bolts of the front seat mounts. I haven't looked under there to confirm.
Ford Bronco 2dr mount points behind front seats? 1707243387972
