2027 Bronco Changes Spied
GPPBronco
Detroit
linktr.ee
‘23 Toyota 4Runner TRD Off Road
They can make incremental changes to “ugly it up” with things like those disgusting wheels. But I’m sure the fit/finish/quality will still be on par with a 2009 Chevy Aveo. So that’s good news, right?
Q1svt
Sunny & Warm SoCal
2025 Badlands, Sas-sy Manual 2dr, # of fords
That is exactly stock Bronco... That is the transmission cooler right where it has always been.
… but IF it’s the RTR being tested for the changes, then it’s a 2.7l auto transmission heat exchanger on a 2.3l… they said their going to use the BRaptor radiator fans….
Ford Bronco 2027 Bronco Changes Spied IMG_8509
… hope people understand these are not spy photos.
They were taken by someone while they were on the Dearborn test facility (not pictures taken over the wall). ;^)
They are showing you what ‘they want you to see….
CarbonGrayBronco
PA
2024 Bronco Badlands
I'm curious to see how the Sasquatch flares, mud flaps, and the non-powered side steps from the 2025+ models (with the flared up edge on the ends of the step) all line up. The mud flap design follows the curves of the vehicle better than the aftermarket options out there.
Bronco4Joe
Joe
F-150 4x4 Southern Comfort
Not a chance.
There's no way they'd just slap a different grille on and call it a day.
The Lincoln LT literally became the platinum F-150
Finbox
FL
KLR650
I don’t know guys looks like they’re trying to class up the Ford bronco and make it a Lincoln, tucking in fender flares, gloss piano black, automated steps, etc. even the raised logo on the side looks like something Lincoln would do
Ducati1098
Just a new bronco package they're testing I'm sure, which explains the different side badge.
Nothing different about the fender flares other than paint.
Ford badge is still on back even though it's covered and still says bronco on the windshield.
Just minor tweaks for a new model year like normal.
rmc523
rmc523
South Florida
2022 Bronco Wildtrak
That was 20 years ago. They don't do that anymore...
Right? this suggestion that this is a Lincoln version because they painted the flares is dumb.
jwhisl
James
Oklahoma
2025 Bronco
It looks to have more ground clearance. I don't see anything sticking down underneath like previous years.
Chrome_Pony
Chrome
The Great Land
Because if there is ONE thing the Bronco absolutely direly needs... its yet another goddamn trim package.
tock13
Tony
WA State
Piano black fender flares? Nothing says “mall crawler” faster. This has to be some upscale version directed at the Range Rover crowd.
Denny Swift
Earth
718 Spyder, 992 GTS, Citroen 2CV, Husky FE350
As long as the top still cracks, and creaks, and leaks, and the db level remains above 80 at 80 mph, and there are at least 3 recalls per year, it will still be a Bronco.
5GENIDN
Joe
Idaho
I wonder if it will have a sun visor that goes all the way to the windshield without hitting the rear view mirror? :rolleyes:
Sounds like you have not figured out that your mirror has TWO pivot points, one at the mirror and one at the windshield... That mirror if properly adjusted will barely fit between the two visors... Neither of my visors strike the mirror and I have the even larger wolfbox monitor instead of the stock mirror.
