2025 base ambient lights
jwhisl
James
Oklahoma
2025 Bronco
Hello I just bought a 2025 base Bronco last night and I read on several websites they're supposed to be ambient lighting in the footwells. I can't find it anywhere.
Ducati1098
Idk if the base has it or not.
But if it does, it’s in the infotainment screen under vehicle settings
bronco 1876
Jack
Boston
Hello I just bought a 2025 base Bronco last night, and I read on several websites that they're supposed to be ambient lighting in the footwells. I can't find it anywhere.
Im pretty sure the base doesn't have it, and you get it with a big bend with the mid package and up. I could be completely wrong, though, so double-check lol.
Scooter M'Gee
Cincinnati, Ohio
2025 Ford Bronco Squatch 2 Door
My window sticker only shows the auto trans and SAS package as options. Everything else is the base equipment group 101A.
itwelder
Lee
SoCal
BaseSquatch 2DR
Mine also does not have it, and it's a 2025 Base SAS, Job 2 build (Nov 2025). In fact if you look under the dash, the light bracket is there, but no light module is installed.
The early 2025 Order Guide lists "Ambient Footwell Lighting" but on the updated guide it is not there. So essentially if you have one built prior to Summer 2025, it has it. Built later in the year, it does not have it.
Deleted member 74291
Guest
Ford Bronco 2025 base ambient lights IMG_2021
Unsure of build date. But 2025 Base. Lighting in footwell but not in other areas. Setting to change brightness and colors buried in the controls
jwhisl
jwhisl
James
Oklahoma
2025 Bronco
I wonder if the wiring is there... I'll have to check later
FG123
Fidel
Chicago
Bronco 2025
That was true for all Broncos until mid-production; now only certain trim levels come with ambient lighting. Any build after July 2025 will only come in certain trim levels only.
23OBX2.7
AB Canada
2023 Bronco
I really need footwel lighting cant even see the golve box key slot LOL its comical they didnt put auto lock globe box and console in softops like they did in Mustang convertibles.
No wonders Ford needs massive competitive obstacles to ROW vehicles haha.
jwhisl
jwhisl
James
Oklahoma
2025 Bronco
Mine was built in October. No lights under the dash at all and the lighting option is gone
