rayep
Ray
2018 F150 Plat
After an hour of messing with it I ordered the sticker fab covers lol
I Just found a way for the Bar at the Headlight to be solid Amber while DRL are on. Do not change the asbuilt file and mess with the 726-43-01 module address of the BDYCM. Chose the other non asbuilf file BDYCM and this file brings up plenty of options. If you go down to the item Left Front Turn lamp usage and click on it you will get options. Mine default was turn only but i change it to turn and DRL in the drop down menu. After writting this change I cycled the power and started the vehicle and with the parking brake applied I put it in drive and sure emought the bar is Amber now with the DRL. I then had to go down to the Right Front Turn Lamp option and do the same thing. Both are Amber now when the vehicle is in drive. So when you put on the turn signal the light goes from amber to off and back to amber. Just what i wanted. Now to order the amber backlights.
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
Yup, once it was daytime I was able to see the change. Now we need to figure out how to make it amber at night too!
@BadBlueBronco
Kc
Los angeles
I'm not travling this week so i have some time to mess with it.
Please let me know. There is a lot of info on the f150 DRLs. It seems like there are 4 or 5 setting that need to be changed on them to get it to work so we must be close.
Vellicate
James
2018 F150, 2014 Flex Limited
I looked around and didn't find an answer. Does anyone know if the spotlights in the mirrors can be enabled at any speed? They turn off above 5mph stock. I was in FORscan earlier and all I saw was enable/disable. Has anyone tried yet or would I be the guinea pig?
Abecker
Aaron
2022 Ford Bronco 2dr
Added sport mode, windows up with key fob, disabled some chimes. Will likely add fogs in the future.
I enabled global close (windows up), but only the passenger side goes up. Is there a solution?
Abecker
Aaron
The day that @D2dhanover gets true stop-and-go cruise control active is the day the entire internet owes him a lifetime supply of beer.
Going to get into this stuff today now that I've got VMware Fusion running on my Mac. Mostly just hoping to change:
  • Add Sport Mode
  • Remove Double Honk when exiting running vehicle
  • Remove doo-doo-doo upon starting up
  • Global Windows-Up from fob (already have down)
I hope this goes without headache, but prepare for my inevitable need for babying when Murphy's Law comes rearing.
I can only get the passenger window to go up? Am I missing something?
Abecker
Aaron
Continue anyway, that is actually supposed to happen. The software will recalculate the last 2 digits to create a "correct" checksum when you change the second digit to a B. Scared me too the first time and I stopped to further research the "incorrect checksum" message before going through with the change. It worked perfectly once I did. Of course, it's always a good idea to make sure you have a saved backup before making any changes, just in case. Good luck!
When I try to add Rock Crawl and Baja to my OBX, I get an error message stating a service interruption. The modes are not added.
amccue90
Andrew
Illinois
2021 Badlands
Your profile pic looks green. I think 2022s are having some issues with forscan
jbryant
Jimmy
Indianapolis
Ford Raptor
I get the same message on mine. I think Ford has locked it down somehow.
jdawg
Julian
NewHampshire
Atlas/65Mustang
rayep
Ray
2018 F150 Plat
Had a little time today. Not that successfull. I chose option 4 which is DRL, Turn and Position and they stay amberwith the head lights on but the turn signal no longer works. the option of Turn and DRL works fine until the headlights come on then they go back to white as you said. May have to dig deeper into the f150 Forscan forum.
@BadBlueBronco
Kc
Los angeles
Ya, same story happened here.
mattm54
Katonah, NY
None
Try the global window reset on each window - that fixed it for me (spreadsheet has it)
Abecker
Aaron
I fixed it. I found several different modules that each had a global window setting. It had to be enabled in every module. Thanks!
