2 door driver seat won't slide forward
Cobragawd
Quebec
2022 2dr bronco black diamond
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Zato_Richy
richy
Bronco 2 door Manual
Hi there, I'd be happy to look into your Bronco concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
Just received my 2 door and it has the exact same issue. What did you guys do to correct the problem after knowing about it for over a year?
Rydfree
Benny
Alabama
Just use a set of pliers and squeeze the 2 ears together slightly.
HoosierDaddy
__ Eric
NW. Indiana
90% of the time, folks just need to lean the seat forward using that upper handle and when it feels like it has stopped, give it a bit of a good shove further, it then releases and slides very easily on the rail.
If that isn't working, either take it in for warranty ... or it sounds like folks have found other solutions, but I've never had to deal with that issue.
The good shove works for me and we use it all the time. Took about 6 or 8 times to get used to the process, It has become second nature at this point.
