Driver door won’t lock
cbrownabq
Littleton, CO
Dodge 2500 diesel
My driver door wont lock. Whether I use the app, fob or button on the door, all the other doors will lock but not the driver door. When I open it, the alarm will go off as if it was locked, but it isn’t. I saw some others have had this issue in the past but never heard what the resolution was. Any ideas? Thanks
flip
Phil
IN
www.ruxerparts.com
Fords
DM me your VIN and I'll see if there's anything in your VHR.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.  
cbrownabq
cbrownabq
Littleton, CO
Dodge 2500 diesel
Absolutely, PM
GaBlackDiamond
Dallas, Ga
2023 Bronco
Did you ever find a solution to this? I have a 2023 Black Diamond. I literally just started having this issue this past weekend when i put my doors back on after being off for a couple of weeks. Everything is fine except for the drivers door. I had to reprogram the window and then started having all of the same issues you mentioned. I can lock the door manually but nothing else will lock the door.
Ford Motor Company
Dearborn
Hi there! I can look into your Bronco's lock concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Bronco's VIN?
cbrownabq
cbrownabq
Littleton, CO
Dodge 2500 diesel
No solution yet. Went to the dealer to see if I coyld just leave me door. They said no…Can’t get in for a month. Pulled the door panel and everything looked ok. Plug on door frame looks good.
GaBlackDiamond
Dallas, Ga
2023 Bronco
I took mine to the dealership and they replaced the door wiring harness under warranty. Supposedly there were a "few of the pins showing resistance" on the plug that plugs into the vehicle. I took at as they were corroded. Hoping this doesn't become a reoccurring issue.
Landry
JoDee
Base 2Door Bronco
Did I miss if this was resolved? Last week my driver side lock just quit working. All other locks engagement, but not on the driver’s door.
Tim
Denver, CO
www.revkit.com
2023 Ford Bronco Badlands 2-Door
My driver door has started doing the exact same thing. Wont lock with the button on the door, the key fob, the key pad, or the app. Was there ever a resolution to this problem?
keefer112
santa cruz
1979 subaru brat
My driver door is now doing the same thing--stopped working after putting the door back on. Looks like a growing issue. Just out of warranty, so the dealer wanted $275 just to do a diagnostic--very frustrating! Has anyone fixed this on their own?
