New 2024 Wildtrak - Sasquatch 4-Door. I had to finally unlock the passenger side door from the driver seat and the lock/unlock buttons did not work. The window works fine. The passenger side works fine with all functions. I disconnected and reconnected the wire harness to make sure it was seated all the way down. This did not help. I assume that the door locks and the window are powered from the same fuse? I looked and it seems as through the Drive door module is powered from a 60-amp fuse #182. Is there anything I can check before taking it to the dealer? About 1,100 miles on it.
Thanks
Thanks
