2.7L Dies While Driving. Diagnoses: battery junction box failure
miami2823
James
Maryland
2006 GMC Sierra
and worrying about it makes it better?
Again enjoy you Bronco. If you are unable to then buy something else that you will enjoy.
Nope, never said to worry about it. Simply saying be aware of what's going on with warranties coverages ahead of time rather than being surprised and coming on to the forum and sayin "wTf WHY didnt they cover X??"
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
I have had my battery junction box replaced, I had a bad aux6 switch that would power itself when vehicle was off and switch was in off position. Quoted time frame is exactly what it took for mine, actually had an additional week of repair becuase they replaced the aux panel first.
I was baffled when they told me not to drive the vehicle until the parts came in. It drove fine though, my 2.7L never died when I had bad parts.
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
@amcdermond : you've got a good attitude. with the vehicle being so new i can practically taste your disappointment and frustration. hopefully this isn't a deep gremlin. Honestly the forum tends to bump issues to the top but i actually have never encountered another 6G owner face to face with any kind of critical issue
cyoungk
C
CA
Bronco Big Bend
I've been warning people about this exact issue and I've been seeing a lot of stories revolving this.
The connecting terminals below the fusebox is VERY fickle. It very easily pops off and will kill the entire car. I had to have my dealership take a deep look when we tried switching out the fusebox (so I can install AUX switches).
I've been seeing more and more stories of people's car dying because the terminals below the fusebox unlatches itself somehow.
JediMcMuffin
Tommy
you got any photos of specifically where this it? I tightened the bolts holding the fusebox in place but I'd like to more clearly understand which connections your talking about.
cyoungk
C
CA
Bronco Big Bend
So when you disassemble the fuse box, there are three white connecting terminals, which you tighten with the three bolts.
so when you tighten the three bolts, it seems as if the terminal connectors are fully seated but it’s actually not. And it’ll loosen up over time and if disconnected in any way, the entire car basically shuts down.
I’ll see if I can find photos from when I was working on it.
amcdermond
amcdermond
Annaliese
Lebanon, OR
2022 2Dr Wildtrak HOSS 3.0, 2020 Honda CR-V
The interesting thing is that except for the engine itself, the electrical systems seemed just fine. The infotainment ran, I wasn't seeing a ton of electrical warnings. The engine just ran really rough for about 10 seconds when I tried to restart it. I would guess that if it really were the fusebox being lose that I'd see a lot more funkiness.
I also did not remove the fusebox for the radio install. The power wires are hooked directly to the Ford provided studs on the battery terminal connectors.
amcdermond
amcdermond
Annaliese
Lebanon, OR
Just an update for those that care. I called the dealer today to check up on things and apparently they now think it’s the PDU. They’re trying to order the part, but they are telling me they have no clue when they’ll be able to get one in. To say I’m disappointed is an understatement.
I also expressed my displeasure to the Ford Customer Relation Center. We’ll see if they bother to do anything about it.
amcdermond
amcdermond
Annaliese
Lebanon, OR
One last update for those who are interested.
After about three weeks of the PCM being on back order, I wrote a letter to Ford corporate. I sent copies to Jim Farley’s office, Customer Relations and to the address on file with the Oregon Secretary of State for the service of legal process. I informed them that they had a week to fix it before Oregon’s Lemon Law came into play. I told them that I really didn’t want a buyback or anything like that, but I asked for some concessions if the deadline were not to have been met. (Full disclosure; I used to be a lawyer in Oregon before I decided to do technology again).
The following week I received a call from a “Consumer Affairs Legal Analyst” with Ford who offered to run things down for me. I let him know what the situation was and he worked on finding out about expediting the part. A couple of days later Ford shipped the part to the dealer overnight FedEx and the dealership got right on it. I now have my Bronco repaired and it seems to be running okay for the moment. I am still waiting to hear from Ford regarding my requests to them for compensation for the inconvenience.
BigBend530
Dominic
Oroville, CA
2022 Ford Bronco 2Dr.
Found this post searching for articles on a similar issue. Bought a new 2022 Big Bend 2 dr. on Saturday (2/4). Had 47 miles on it when I test drove it. Had about a 3 hour drive home. It cut out twice before it finally died while going down the highway on the drive home a little over 2 hours into the trip. Finally able to get it refired and got it home. Took it to local dealer on Monday (2/6). Said its likely the battery junction box. Found a dealer across the country with one. Part expected to arrive on 2/14. These things happen, it just hurts more on the first drive home.
I do plan on getting in touch with Customer Relations just for the mere fact I would expect a little happier first few hours of owning a Bronco.
Central Florida
Navigator, 79 F-100
BigBend530
Dominic
Oroville, CA
See below for similar issue to yours and OP's if you haven't already seen. They seem to say it is the junction box first and then move on to PCM. Took over a month to get the PCM after they ordered. Best of luck that yours just ends up being the junction box.
https://www.bronco6g.com/forum/threads/641-miles-on-2-7-bronco-and-here-comes-the-tow-truck.60828/
Well after reading your comments and the link, it came as no surprise that after waiting 9 days the new junction box didn't fix the issue. Service manager felt it had to be the PCM and zero are available with no eta for new orders. Called Ford Customer Relations for a 2nd time in 2 days. They talked with service manager and will have full response tomorrow but did approve my part request as high priority.
Also got a loaner vehicle, a brand new 2023 Explorer with 20 miles on it. And to think I was waiting to see a Focus or Fiesta.
Defyfate11
Jaime
Clovis, CA
2020 Camry TRD
Can you provide an update please
BigBend530
Dominic
Oroville, CA
I'm at around 1200 miles, or roughly 940 miles on new PCM, and have not had any similar issues. Ford Customer Relations told me while it was in the shop they often give extended warranty in cases like this as a measure of good will. I have called and left the case manager two voicemail and emailed her formally requesting an extended warranty and they havent called or emailed and it's been over a month. Dealer told me to open a reacquired vehicle case in order to push them into doing it.
