2.7 engine cover installed
HoosierDaddy
__ Eric
NW. Indiana
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Thanks to @JcrOffroad fir a great product.
Original thread
https://www.bronco6g.com/forum/threads/2-7l-and-2-3l-engine-covers-jcroffroad.56517/
Quality product. Easy to install, 3 mounts that screw into 3 open holes. Takes longer to find the holes than to install it.
I know everyone sees a engine cover. I see a spot to cook, reheat, defrost, and keep the coffee warm. Nothing some rivet nuts and a couple small cooking racks won’t fix. Gonna thermal it tomorrow. See what temp she gets up to.
I did paint mine, drilled out the mounts and added m6 rivet nuts for my thumb screws.
Thanks again for a out of the box product. Definitely gonna come in handy!
That turned out great!
Ground_zero298
Ground_zero298
Scs michigan
I get it. I put mine on my toolbox. It just looks really cluttered, so you covered up the cluttered engine bay with something to make it look clean, then made it more cluttered.
JR
Man some of you are so easy. Lmfao
Ford Bronco 2.7 engine cover installed 9B14165B-D52C-42F0-977C-68698789DD13
Gtrekker
Gary
Original thread
Nice!!! Mine is due in and plan on painting as well, AMB.
Like the nut rivet idea!!!👍👍
What are the two Items sitting on top?🤔
Gtrekker
Gary
Ground_zero298
Ground_zero298
Scs michigan
Single burner plate and coffee burner. Just another spot to use them while parked to save space.
Ground_zero298
Ground_zero298
Scs michigan
Keeps it from getting rained on 😉
Ground_zero298
Ground_zero298
Scs michigan
Shake down run on the cover today. Little tight with my rt hood. Will relocate the bronco emblem and may take a 1/2” of the mounting legs which I will have to key and make adjustable or cut and weld.
So for hotdogs you just throw them on top and close the hood. Don’t think they’re going anywhere.
Ford Bronco 2.7 engine cover installed 17B74A14-7BAC-4FF3-9910-3F43A515C4DE
Ford Bronco 2.7 engine cover installed 7A3F3978-A28A-4609-82A4-12A0134446E0
Neps
Floating off California
MX-5 30th, Focus EV, F150, Scout II (2)
Any idea of engine temperatures before / after installation? I'd be concerned about hot spots and heat soak.
Ground_zero298
Ground_zero298
Scs michigan
You forgot to put lights in it.
Lmao. I didn’t. They’re in the underside of the hood. Pair of kc pucks. Do have red leds going in to light all the vents up.
Ground_zero298
Ground_zero298
Scs michigan
For running temps while wheeling I was actually running about 10 degrees cooler. 213 for most the day on engine. 193 was max on trans. I’m usually close to 230 and 215 and that was with the vented hood last time.
So no. I noticed no difference with the cover on.
Highway I was around 183 and 173.
Ground_zero298
Ground_zero298
Scs michigan
When it’s open, one usually needs to reach the engine.
That’s why I changed out to thumb screws.
