2.7 engine cover installed
mpeugeot
When it throws a valve, Ford will blame the plate for overheating the valve train... LOL 😂.
Ground_zero298
Ground_zero298
Scs michigan
Wouldn’t put it past them. That or the after market valve caps.
Roger123
Roger
VA Beach, VA
When it’s open, one usually needs to reach the engine.
Why? Nothing you can do under there unless you're a Rocket Scientist 😀
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
What are you talking about? This engine is one of the easiest to work on. If you have mechanical skill
Roger123
Roger
VA Beach, VA
Define "work on", I've been wrenching on Bronco's since 1983. This one doesn't have too many user serviceable parts. And it literally takes 30sec to get the cover off for you to "work on" it.
Ground_zero298
Ground_zero298
Scs michigan
helifino16
Ron
Mount Sinai, NY (Long Island)
That’s why I changed out to thumb screws.
Got mine yesterday - I really like the thumbscrew idea. Will have to research what I can use to replace those.
Ninjak
Miami
I like that cover. Looks good. Hmm I would like to do an Oxford White and Black for mine.
Though I do not need to cook :ROFLMAO: The FL heat in Miami will handle that on its own! Would not even need to turn the truck on....Just open the hood!
Ground_zero298
Ground_zero298
Scs michigan
Mine won’t get hot enough anyways with the vented hood. Maybe in the summer but no way under 70.
Ground_zero298
Ground_zero298
Scs michigan
