2.7L Engine Cover?
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
wetdog
Bruno
pacific coast
2019 jl
It takes a chip so its a deleted item.
Y2KFirehawk
PA
2022 Bronco Wildtrak
Do like the looks of the factory piece; surprised more have not done it.
8rent
Brent
So here it is - I purchased a new new F-150 cover and two studs to mount it.. The holes in the cover line up perfectly with the tapped holes in the manifold for the studs. The cover itself fits but did require me to trim away some of the plastic on each side to clear the turbo plumbing and wiring on the Bronco. It is currently mounted with just two studs but there is what appears to be some type of clip needed for the center in the rear - I'll have to research that a bit more. I mounted a cheap Bronco emblem on the front of the cover that I found on FB. I might remove the cover and paint it to make it look a bit better. Total cost for everything was about $65. took about 45 mins to trim and mount it.
Do you have any pictures that show the trimming close up?
8rent
Brent
I saw some discussion of this, curious if anyone is bored enough to try and see if the F150 engine cover will fit. Perhaps you have a 2.7L F150 or a 2.3L ranger/mustang and want to try swapping it over.
Part # JT4Z6A949A
https://parts.lakelandford.com/p/Ford__F-150/Engine-Cover-27-LITER/68937276/JT4Z6A949A.html
Well, I was bored enough to try. Had to trim a lot off a 2018 f150 cover for the 2.7. Clearance on hoses is tight and hood insulation is either touching or very close.
Ford Bronco 2.7L Engine Cover? IMG_7245
Ford Bronco 2.7L Engine Cover? IMG_7244
Ford Bronco 2.7L Engine Cover? IMG_7243
