2.7L Engine Like Knock
Tommy Weishuhn
Tommy
2024 Bronco 2 door hardtop big bend sasquatch
2024 Badlands sqautch. Also a knock at idle in gear. No noise in neutral or park. Took it to dealer. Dealer said it was normal. I made them log it on a service order to cover my a—. Mine has 5500 miles on it. Never heard it when I purchased the vehicle and somehow it’s now normal
Aknobronco
Ak
Gulf States
F150 F350 Wrangler Taurus Mustang Camaro Cmax
Has anyone else noticed and "engine like rod knock" when you are stopped with the transmission in gear ( forward or reverse doesn't matter) knock changes with rpm until it goes away or occurs to fast to distinguish over 1200 rpm. The knocking sound instantly goes away while in Park or Neutral
Dealer couldn't find the source of the noise, said they coal hear it from the engine right through to the transfer case, they referred it to dealer support.
Dealer support asked them to find a vehicle with same drivetrain and compare, apparently that bronco made the same noise
Ours is a Black Diamond and has rubber floor with little insulation, so maybe noisier than one with carpets.
Has 30,000 km on it and hasn't got any worse so probably not anything serious
any one else noticing this noise?
Try thicker oil. Stealerships are well known to use barrel oil of weight that fit most vehicles they serviced. Probably 5w20.... :(
SledDog30
Bob
colorado
Same here. 24 Wildtrak. Sound when in gear. No sound in neutral. 8000 miles. I’m gonna schedule a visit for early next month.
Tommy Weishuhn
Tommy
Let us know what the dealer said? Somebody gonna find the issue. I’ve gone as far as crawling under and prying the access cover to check torque converter nuts for being loose. All were tight.
Tommy Weishuhn
Tommy
SledDog30
Bob
colorado
I think it may be trans related. But I’ll post what the dealer says.
JL8jeff
Ewing, NJ
I can barely hear it at 500 rpm idle in gear in cold weather. I've never heard it previously but I might not have been paying attention since it's so low. I had an old 93 Z28 that had some piston slap after the oil started to get a little old. It would always go away after an oil change.
