2.3 versus 2.7
Mr. Nice
Jayson
Minnesota
12' Boss302, 08' Audi TT, 13' CRV, 14" Ridgeline
Having driven my 2.3L and had to brake hard.... No I'm not worried.
Although it's good to see the forum speculation = reality effect is working strong!
More speculation...
2.3 Bronco 2 dr Black Diamond
Also, it's a good thing L.A. traffic isn't moving well today, because stopping from 70 mph requires a lengthy 217 feet.
CAR and DRIVER
Ranger (2.3 Bronco and Ranger share same brake system)
And not only was its 193-foot stop from 70 mph the longest here, but the pedal feel was genuinely frightening. It sank through a couple of inches with no resistance or response and then grabbed with an immediacy that frequently had our heads bobbing.
CAR and DRIVER
https://www.bronco6g.com/forum/thre...ay-known-issue-according-to-dealership.30961/ Sep 8, 2021
Feb 23, 2022
What about that one pedal drive delete on the 2.3?
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
I went 2.3 to get away from the plastic oil pan. My 2016 F150 still leaks after multiple attempts. Right now I feel that the 2.3 is the more long term option.
Power wise I couldn't tell the difference but never got to do a back to back test drive. I would be in the buy the biggest engine possible group but I have been so happy with with my 2.7 F150 power.
BigHoof
PA
Ram 2500
I ordered the 2.7 mainly because it is the more up to date engine. Direct Injection engines usually end up with a heavy carbon build up on the valves which can be a real pain to maintain (clean). The newer design of the 2.7 also incorporates Port Injection to help wash the valves and keep them clean. Get the extra boost of power too so to me, it's a no brainer.
Both are equally complex so not seeing that argument.
Baseaf
Base Bronco
2.3 for me. After having a 3.5 twin turbo king ranch I've learned the less turbos the better once you are past 100k lol. I plan on keeping this long term so I wanted the easier/ cheaper engine to maintain. The 2.7 is sweet though, you def notice the difference in sound and how it pulls.
heynow14
Nick
Yorba Linda, CA
2022 Bronco - BL SAS MT LUX SOFT
People forget that the 2.3 comes with the deficient vacuum assist brakes. Aren’t they worried about stopping? How about losing one pedal drive?
ZERO concern from me about anything noted above. What I am gaining is 7-spd manual which is the single best thing about my BL SAS. There are a lot of great things about it...the manual is the best.
2.7L?
Bye Felicia.
DogHauler
Chuck
New England
2022 Badlands Sasquatch 4dr 2023 Black Diamond 2dr
I was most concerned with the remorse of driving a 10-spd automatic. #savethemanuals
The Ford 10-spds are fantastic! They'll smoke any stick vehicle for 90% of the driving cycles.
Manual transmissions are fun, I have a GT500 6-sp. 8-tracks are fun too.
Go Devils
Reed
Did they not work out the issues with leaky plastic oil pans in 2018? I believe it was the RTV sealant that was to blame and now they use a press-in gasket? We’ll see, I guess.
mike8675309
Minnesota
you won't find much on 0-60 times because that really isn't what the bronco was built to measure against. I.e. the goal of the 2.7 isn't to decrease 0-60 times or even 60 to 0 times.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
At 25K miles a year, by the 3rd time it started leaking again I declined to pay out of pocket. It just marks its spot and only burns a 1/4 quart between oil changes so let it ride. I also don't like the plastic pan/oil drain plug, after 15 oil changes it has a small drip even with a new plug.
