2.3 w module = stock 2.7???
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
There's a 20lb difference between the two transmissions, not motors
2.3 Ecoboost:
  • Production Run: 2015 – Present
  • Cylinder Head Material: Aluminum
  • Cylinder Block Material: Aluminum
  • Configuration: Inline-4
  • Bore: 87.5 mm
  • Stroke: 94.0 mm
  • Valvetrain: DOHC four valves per cylinder
  • Displacement: 2.3 L (2264 cc)
  • Compression Ratio: 9.5
  • Weight: 418 lbs.
  • Maximum HP: 350 HP at 5,600 RPM
  • Maximum Torque: 350 lb-ft at 2,750 RPM
2.7 Ecoboost:
  • Cylinder Block Material: Compacted Graphite Iron
  • Configuration: V6
  • Bore: 83.0 mm
  • Stroke: 83.0 mm
  • Displacement: 2.7 L (2694 cc)
  • Compression Ratio: 10.3
  • Weight: 440 lbs. (Dry)
  • Maximum HP: 330 HP at 5,000 – 5,750 RPM
  • Maximum Torque: 400 lb-ft at 3,000 – 3,250 RPM
SPITmadFIRE
CA
2.3 Ecoboost:
  • Bore: 87.5 mm
  • Stroke: 94.0 mm
  • Weight: 418 lbs.
2.7 Ecoboost:
  • Configuration: V6
  • Bore: 83.0 mm
  • Stroke: 83.0 mm
These numbers themselves seem a bit confused — they’re quoting the Focus RS 2.3L configuration power numbers, not the config you’ll find in the bronco. I would assume they’re factoring in only the long blocks and not the turbos, various accessory belt components, etc. not only that, but notice the materials — all aluminum on the 2.3L, but the larger V6 block uses an iron block. There’s no way there’s only 22lbs difference between them in actuality.
N8Mash
Nate
Charleston, SC
GTI
2.3 Ecoboost:
  • Bore: 87.5 mm
  • Stroke: 94.0 mm
  • Weight: 418 lbs.
2.7 Ecoboost:
  • Configuration: V6
  • Bore: 83.0 mm
  • Stroke: 83.0 mm
Thats damn impressive! 22 lbs for 2 extra cylinders?
What about fluid fills though? Oil, coolant? Is there an appreciable difference in capacities?
Also, I would think a second turbo and supporting equipment would add more weight as well.
Still, I'd ballpark it to be maybe ~60 lbs difference between the 2 drivetrains?
1970AMCAMX
Robert
Titusville, FL
The designs are completely different: The 2.3 still has an exhaust manifold while the 2.7 the exhaust passages are in the heads without a manifold, V6 Crankshaft is shorter and also has a shorter stroke possibly making it lighter, etc.
I'm sure that there are some differences in the weight of the ancillaries between the two motors: V6 may have a larger radiator, Extra plumbing for the twin turbo setup, etc.
Even if there is a ~200 lb difference in total vehicle weight between 4 or 6, that is insignificant in a 4000+ lb vehicle.
Lowcountry Bronco
William
South Carolina Lowcountry
elseminoleguapo
Javier
Miami
Basesquatch
Based on what I've read on the Panda module...it looks like the 2.3 version nets a HP increase of at least 8%. That puts it at 324hp. The stock 2.7 is rated at 330 HP. So for $600 or so the module turns the 2.3 into the 2.7 while giving you the option of manual or auto. Am I looking at that (somewhat) correctly???
In short, no. Peak power numbers don't tell the whole story or accurately reflect how you'll use the car day-to-day. The power band is a way more nuanced way of looking at how a car will perform on the street. While Panda's numbers look promising (especially if you're 7MT or bust), the power band on the 2.7 still looks better, IMO.
Panda 2.3 numbers:
Ford Bronco 2.3 w module = stock 2.7??? 1638480814360
2.7:
Ford Bronco 2.3 w module = stock 2.7??? 1638480851178
Panda 2.3 is peaking in power way later and not sustaining that power for very long. The 2.7 peaks at 4.5k RPM and hold it through 5.5k. I don't know about you, but if I had a 2.3 7MT, I don't see myself getting it to the 5.5k RPM range with any kind of regularity, but shifitng around 4.5k-ish for onramps and passing seems reasonable.
That said, is the 2.3 with the tune good enough to make you not miss the 2.7? Possible, but that's up to you.
theguda
theguda
IN
2013 Ford F-150
Panda 2.3 numbers:
2.7:
What's you opinion on the 2.7 module?
elseminoleguapo
Javier
Miami
Basesquatch
I'm a Grangetober reservation holder, so I'm not seriously in the market for any tune right now. I don't know enough about Panda or tuning turbo engines to comment one way or another on their product and quality.
I am generally skeptical of the claim that you can remove the module without the dealer ever knowing and not affecting your warranty. I've heard similar claims about ECU tunes, and personally know people that have been caught. The mechanism might be different, but whenever a company the size of most small tuners outsmart Ford, it's always a question of how long can they do it for?
As it stands, I don't see much benefit in going aftermarket today vs. waiting for Ford to release their own tune and seeing how it stacks up.
ColoradoGuy
Well, that does it. You talked me into getting the performance pack for my 2.7L.
DrewBronc21
New York
2020 Subaru STi, 2024 M2
But one could argue over the lifetime of the vehicle it’s not worth it to run the 4banger under more strain
You could argue that but plenty of very strained 2.3 Ecos out there in mustangs, focuses and Mazdas doing well. I’ve had some highly strained Subaru 4 bangers running like tops for many years as well.
and at the same time there’s stock 2.7s spewing coolant so who knows. I personally would rather have a manual over the slightly bigger 2.7 and will modify it knowing it’s not without risk
navi
Navi
CA
73 Bronco
I think a ford tech mentioned here that a lot of those mustang eco's end up failing at 60-80k miles. And that is a much lighter vehicle.
The coolant spewing is a result of Ford copying BMW's dumb idea of forgoing clamps for push in hoses. Not related to the motor at all.
VictoryLights
Pittsburgh
2018 Honda Pilot
I can’t imagine risking my powertrain warranty by tuning a brand new vehicle.
