- Christopher
- Aug 27, 2020
- 2
- 280
- 321
- West Virginia
- Wildtrak, F150 and Taurus.
- Wildtrak
I'm too biased on this topic. Good luck.
There was a brief run of 2.7 issues in the early 2021-2022 bronco. Nothing else since.My observation is that most of the people complaining about engine issues all have 2.7s. That's just an observation. That said, I can't get a manual with a 2.7, so the 2.7 will never be relevant for me.
I wanted a manual too, but not at the expense of 40hp and nearly 100ft lbs of tq. These stupid bricks are slow enough already. It would be torture to drive a 2.3 as a daily. Sure, crawling is probably barely noticeable until the missing torque is actually neededMost replies to this are probably going to be: "Because I wanted the manual."
I wanted the manual until I test drove a 2.3 manual and then a 2.7 auto back to back. The low end torque on the 2.7 is much better. You need to keep the rpm's up in the 2.3 to make it get up and go.
But that's highway driving... off-road either is great and you probably won't know the difference due to the slow rock crawling speeds.
If I didn't have a manual in my car, I would have settled for less grunt so I could row gears.
Actually the slower stuff is where I noticed the 2.7 being a lot better with the additional torque.Most replies to this are probably going to be: "Because I wanted the manual."
Can phasers still. It's was a 2024. Phasers went at 1500 km on the odo onlyThere was a brief run of 2.7 issues in the early 2021-2022 bronco. Nothing else since.
That's not a super common issue for the 2.7. It was very common in the 5.4,Can phasers still. It's was a 2024. Phasers went at 1500 km on the odo only
Why is 2 door a "must have" for you? Is it strictly an appearance thing or is there some sort of other preference there?I had 3 “must haves” (2dr, 2.7 & Sasquatch) ended up having added big bend and tow on the one I bought…very happy...the 2.7 is good enough but a supercharged V8 would be better…removing the 2.7 from the 2dr takes me out of the bronco market…
Because Ford only gave me a 4cyl. I have had both. The 2.7 is a sweet engine. If I didn’t make the switch I would be 100% happy with it.Legitimate question...why would anyone WANT a smaller, less powerful engine?
For me, yes, it's an appearance thing. I haven't liked 4 doors since I was a kid. If a 68 Chevelle or a 66 Fairlane doesn't get a free pass, a 202X Bronco sure as shit is not getting a free pass. That said, I do like the shorter wheel base and feel for a daily driver, that short wheel base is superior as it's quite handy in a parking lot.Why is 2 door a "must have" for you? Is it strictly an appearance thing or is there some sort of other preference there?
That’s crazy drama talk honestly, saying it would be torture and it’s so slow, the torque is needed.I wanted a manual too, but not at the expense of 40hp and nearly 100ft lbs of tq. These stupid bricks are slow enough already. It would be torture to drive a 2.3 as a daily. Sure, crawling is probably barely noticeable until the missing torque is actually needed
