2.3 oil change, drained over 6 QTs
murrman
Sean
Toledo, OH
2024 2 Door Black Diamond
I just completed my first oil change. I drained and added 6 qts (plus replaced filter). I discovered the hard way that I definitely drained more than 6 qts from the vehicle when I accidentally overflowed both oil containers putting the old oil in. I just want to confirm that 6 QTs is the correct amount of oil for a 2024 2.3L. Based on the dipstick, it doesn’t seem to be running low.
Assuming 6 QTs is the right amount, does that just mean the dealership put too much in when they did an oil change before I purchased it?
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
I believe it's 6.2 with a filter change.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Uh; I thought it was 5.6QT/5.3L.
VirginiaHeritage
Frank
‘25 Bronco HE
Hold on. The 2.7 is supposed to officially be 6 qts now. I would expect the 2.3 to be less, not more.
OP, do you know that an oil change was done before purchase? Because the factory overfilled on my ‘25 2.7 by quite a bit.
murrman
murrman
Sean
Toledo, OH
Yes, I know they did one right before purchase. I bought it last summer new, but it had 700 miles due to being a courtesy vehicle. Part of the sale was them doing an oil change. It’s a 2024. It wouldn’t surprise me if the 2025 had a different capacity since it’s an entirely different engine starting with that year.
RagnarKon
Ford Bronco, Escape, Focus
2021-2024 Bronco with the 2.3L is 6 quarts.
Other Ford vehicles with the same 2.3L engine may or may not be 6 quarts depending on the model/year. For example... Explorers had a different oil capacity than Bronco despite having the same 2.3L engine.
UncleBrad
Brad
2024 Bronco 2-DR Manual
There is what is specified in the documentation and forums, and actuality. My 2024 2.3L 7MT required 6 quarts to reach the top fill mark on the dip stick after a thorough drain. I've done four changes so far, and every time I come to the same conclusion: what was Ford thinking? The filter is not easy to get to - even through the wheel well. Some good filters, like the Mobile1, have rounded-over teeth, so a removal cap doesn't work. Wix filters are much better in this regard.
And Ford: putting that goofy drain trough in there doesn't help much in keeping things clean.
I understand the 2.3L MPC oil change process has improved the situation(?)
bf4445
Britt
Oregon
2007LarietCC4x4, 2018FocusTit, 2016Jeep reneTH
Two dealerships over-filled oil in two of my other vehicles (Kia and Subaru). Since then I do my own oil changes. You'd think a dealership familiar with their own vehicles would get it right, but unfortunately that's not always the case.
I've noticed that i often end up putting less oil in vehicles i change oil in than what the manual calls for. If i put the amount in it says in the book I would have to remove some or be over filled. I think the reason for this is that not all the oil will drain there will be residual oil that stays in different places in the engine. Every time the dealer changes oil in my 6. ah oh when i check the oil its always over the fill mark so i suck some out.
