- Tim
- Sep 24, 2020
- 29
- 909
- 2,749
- Pittsburgh, PA
- Website
- www.youtube.com
- 2003 Jeep WJ Grand Cherokee Overland
- Base
Back in August of 2021 I was one of the first to mount 285-75-R16 tires on Base steel wheels. See full post linked here. At the time a lot of people noted that these tires might not wear properly because they are designed to fit on a rim width of 7.5 to 9 inches, and the Base steelies are only 7 inches wide. The thinking is that compressing the beads inward will cause the middle of the tread pattern to bulge outward a bit, and cause uneven tire wear.
So now that I have 30k miles on the Bronco and all 5 tires have been through a full cycle of tire rotations, in the words of Project Farm, we're gonna test that!
I used a tread depth gauge to measure each tire in three different places around the circumference, and at each testing point I measured the tread depth at the inner tread, middle, and outer tread. Here is the table of measurement results:
My calculation of 'Bulge' shows the average difference in tread wear between the inner/outer tread and the middle of the tread. So sure enough, the tires are wearing a little bit faster in the middle, about one and a half 32nds of an inch over the 30k vehicle miles so far (each tire has about 24k road miles since I use the spare as part of my rotation pattern). I guess the real question for this audience will be, is this amount of increased tread wear acceptable? In my opinion, it is.
Also by using the rate of wear so far, I can project that the tires should get to 60,000 miles before they wear down to 4/32 of tread left at which time they should be replaced.
See below with video of full results and let me know if any questions
