Marie_ARB
Marie
Maple Valley, WA
Toyota 4Runner
Ford Bronco The ARB 4x4 Integrated Winch is now available for your Bronco build! 789713-5cce49d1fa228936b0820fd2df9b0128
We just launched a new winch, designed around how modern 4x4s are actually built and used. And if you're already running our Summit Winch Bumper, or have been eyeing one, this is the recovery setup you've been waiting for. Here's the full breakdown.
About the Winch
The new ARB winch is a compact, fully integrated recovery winch available in 10,000 lb and 12,000 lb ratings. It was built to handle the demands of modern, heavily equipped 4x4s. It features consistent power, smart heat management, and an easy install that works within the tight packaging of today's bumpers.
Check out the new ARB Winch here!
Top Features
  • 10k and 12k winch options
  • Electronics integrated directly into the winch housing, meaning no bulky external control box
  • 4-stage hardened steel gearbox for smooth, controlled pulling power under heavy load
  • Gearbox-mounted brake for 100% load holding and powered unspooling without damaging the winch
  • Synthetic rope is standard because it’s safer and easier to handle than steel cable
  • Dual connection remote with 2.4 GHz wireless up to 130 ft, plus a hardwired option up to 16 ft
  • IP68 rated for water and dust protection
  • Pre-wired connections for a clean and hassle-free install
What Sets It Apart
Ford Bronco The ARB 4x4 Integrated Winch is now available for your Bronco build! Bronco_winch_1
Most winches on the market haven't changed much in years, and while they get the job done, a few well-known pain points tend to show up when things get serious. Here's how we tackled them.
Heat is the first problem. On many winch designs, the brake sits inside the drum, which transfers heat directly into your rope. What this ends up doing is degrading your line and hurting performance. Because of this, we moved the brake into the gearbox, keeping it away from the drum entirely. Less heat on the rope means better durability and more consistent performance, pull after pull.
Electrical complexity is the second. A separate control box means more wiring, more connections, and more potential points of failure, especially in wet, muddy, or dusty conditions. We replaced it with a custom Albright contactor built directly into the winch, sealing everything into one compact, IP68 rated unit. Fewer connections means fewer things that can go wrong when you're already in a stressful situation. And the pre-wired connections mean installation is straightforward.
Performance drop-off is the third. Many winches start off strong at first, but tend to slow down as they heat up under load. Our 4-stage hardened steel gearbox and tuned 12V motor work together to maintain consistent pulling power and line speed through extended recoveries.
Want to know more? Read more about our winch here.
10K vs 12k
Ford Bronco The ARB 4x4 Integrated Winch is now available for your Bronco build! WINCH
ARB 10K Winch
ARB 12K Winch
RATED LINE PULL​
10,000 LB | 4,536kg12,000 LB | 5,443kg
ROPE​
10mm x 92 FT Grey Synthetic11mm x 79 FT Grey Synthetic
FAIRLEAD​
Forged 6061 Aluminum Hawse FairleadForged 6061 Aluminum Hawse Fairlead
FITTED WEIGHT​
73.5 LB | 33.3kg76 LB | 34.5kg
MAX. LINE SPEED​
60 FT / MIN65 FT / MIN
MOTOR​
5.3 HP5.7 HP
ELECTRICAL CONTACTOR​
Albright DC Contactor – 500 AmpAlbright DC Contactor – 500 Amp
BRAKE​
Gearbox Mounted 100% Load Holding Proportional Friction BrakeGearbox Mounted 100% Load Holding Proportional Friction Brake
GEARBOX​
171:1 2-Stage Planetary and 2-Stage Spur171:1 2-Stage Planetary and 2-Stage Spur
WATERPROOF RATINGS​
IP68 Winch Motor and GearboxIP68 Winch Motor and Gearbox
INCLUDES​
Main Power Isolation Switch and Remote Mounted Control PlugMain Power Isolation Switch and Remote Mounted Control Plug
WARRANTY​
Limited Lifetime Warranty and 7-Year Electrical WarrantyLimited Lifetime Warranty and 7-Year Electrical Warranty
Pair It With the ARB Summit Winch Bumper
Ford Bronco The ARB 4x4 Integrated Winch is now available for your Bronco build! Bronco_winch_4
If you're adding a winch to your Bronco, you'll want a bumper that's built for it. The ARB Summit Winch Bumper is a full front bumper replacement designed specifically for the 6th Gen Bronco, rated for winches up to 10,000 lb, and built to keep your factory adaptive cruise control and parking sensors fully functional.
Want more info? Check it out here!
Have questions?
We know there are a lot of questions that come with a purchase like this. Which capacity is right for my build? How does it install? Is it worth the price over other brands?
Drop them below. We're here to help answer any questions you may have!
Ford Bronco The ARB 4x4 Integrated Winch is now available for your Bronco build! 1776188430652-yh
Ford Bronco The ARB 4x4 Integrated Winch is now available for your Bronco build! 1776188430674-8c
Ford Bronco The ARB 4x4 Integrated Winch is now available for your Bronco build! 1776188430770-88
Jesse
Orange, CA
2022 Ford Bronco
Can this work with Ford Steel modular bumper? I am assuming I would need an aftermarket winch plate and relocation kits for the camera and ACC.
DaddyO
Jules
Austin, Texas
2024 Bronco 4D 2.7L Sasquatch
Where is the brake release to pull out the rope? I have a hidden winch installed in the ford steel modular bumper and cAnt get to mine.
monsterfd
2014 raptor widebody 37s, 2018 raptor 2018 JKU 35s
its on the right cap, but mounted in the front instead of up top
ericwmedic
SE Michigan
17 Focus RS NB
Some of your pictures show the brake lever on the "front" of the winch, while the pics on the site with the red Jeep show it on "top" (assuming the mounting holes are vertical). Can that endcap be clocked or adjusted to place the level where it best fits?
Also, where are these manufactured and/or assembled (if in a different place)?
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
Looking at the manual now, you can rotate it by removing four bolts
Ford Bronco The ARB 4x4 Integrated Winch is now available for your Bronco build! 1776194976258-ph
ericwmedic
SE Michigan
17 Focus RS NB
Jason N
BadSquatch
Good thing I haven’t pulled the trigger on front bumper winch setup yet. Mos def getting this!
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
If you compare it feature wise to a Warn direct comparison, it’s way cheaper.
Yah but you can get a Taiwan made Come Up winch for a few hundred more. I don't want stupid features, I want a robust and simple tool that lasts.
The Bronc
MJ
Nashville, Tennessee
04 Xterra; 04 Element; 06 Sentra; 10 Rav4
Love that it works with the Lux package.
