Ducati1098
Recently had a chance to install CVF's new high mount intercooler setup so I wanted to give an overview and review.
Huge shoutout to @CVF-Jason for getting this thing out to me quickly so I could do some testing while the temperatures were still hot out.
https://www.cvfab.com/collections/i...oler-2021-2024-ford-bronco-2-3l-2-7l-ecoboost
Small backstory: I already had an aftermarket stock location intercooler installed. It did a good job of managing charge air temperatures with stock turbos, but I realized a while ago after installing larger turbos that it was really struggling to keep up with the additional heat/boost.
Installation was extremely easy thanks to the thorough installation video @MWILD made.
My installation was slightly different than normal.
This intercooler kit is currently designed to work with factory charge pipes. However, I already had aftermarket charge pipes installed and did not want to remove them. Luckily I was very easily able to get a few 45 degree silicone hoses to make it work with my charge pipes. YMMV if you try to do this.
I would assume that CVF will eventually make a kit in the future that allows this intercooler to work with their own aftermarket charge pipes.
Ford Bronco CVF High Mount Intercooler install and testing IMG_8638
Ford Bronco CVF High Mount Intercooler install and testing IMG_8637
Ford Bronco CVF High Mount Intercooler install and testing IMG_8639
Here is a small snapshot of data that I was able to get showing the difference between the aftermarket stock location intercooler and the new high mount:
Tried to make both logs as close to the same as possible for a good comparison.
This is a 4th-6th gear WOT pull. Both were done on very similar days with an ambient temperature of 80 degrees.
Aftermarket stock location intercooler:
CVF high mount intercooler:
Very easy to see just from this short pull, that the high mount does a far better job of keeping charge air and manifold charge temps down, while the stock location intercooler really just starts to spike the temperatures the longer its pushed.
There is also a very large difference during normal every day driving. The stock location intercooler seemed to get heat soaked very quickly and once it was, there was just no way of bringing the temperatures back down to a normal range. While the high mount stays much closer to ambient temperature at all times even after getting hot.
PWillette
Parrie
Maine
Wow, that puppy has some surface area! Nice results (y)
Wyld2dr
2023 2 dr Bronco; 2016 Audi A7 tdi
This seems SO much cheaper than going with Mishimoto. Am I missing something?
MWILD
Central North Carolina
2021 Base/2DR/2.3/MT & 2023 Model S Plaid
I had the same Intercooler install on my Bronco for 7 months or so and it's been amazing. My results mimic what the OP is seeing. I was having the same heatsoak issues with my CVF FMIC, but we're also both custom tuned on E85 ;)
Even cheaper if you use the code "Fullspeed" - Out the door with no taxes or shipping for $817 :)
Ducati1098
Ducati1098
I have no experience with the high mount Mishimoto one. I simply went with the one that I thought would give me the best results.
The CVF intercooler also seems a lot bigger just from looking at pictures. They really utilize all the available room.
I'm sure the Mishimoto one is great, but for the price you can't beat CVF
Ducati1098
Ducati1098
While I love the size and added space, how much airflow to the radiator is being lost? Have you tracked coolant temps?
Coolant temps haven’t changed at all. I sit in stop and go traffic for like an hour on my way home from work and it never got any higher than usual.
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
That video is nice and informative.
I wonder if there are any differences if any compared to the Wagner Tuning IC. The only thing I really noticed is the hose clamps @Ducati1098 used are better quality. Also the charge pipe coupler is silver, where the Wagner is black.
Is there a reason you chose to run both top angle brackets the same direction?
Ducati1098
Ducati1098
They look very similar. I honestly don’t know if there is really different at all other than the few things you mentioned.
As far as the bracket, It seemed like the brackets should’ve been different per side for them to fit correctly (I could be wrong though) but both of mine were the same. So I just decided to mount it like that because it seemed to make the most sense at the time. Realistically they’ll work either way. I think I was just overthinking it lol
Squatch
I tested the CVF stock location intercooler, love it and no problem with FP Tune. I am interested in a new hidden winch that needs a high mount, so I hope it's compatible. :thumbsup:
Ducati1098
Ducati1098
Which hidden winch are you looking at? I was thinking about doing one also now that I have all the room
