120v ac outlet ideas
Jmax
Plymouth
Explorer
I thought the bronco would come with a standard US plug style 12v. Anyone have any good ideas to install? I am thinking the kids will need a heated blanket in the back considering the horrible airflow.
RagnarKon
Ford Bronco, Escape, Focus
You should have at least two of them—one in the center console and one in the back cargo area of the vehicle on the passenger side.
Jmax
Plymouth
Explorer
Let me rephrase, I am no electrician. How do I go about converting/putting in the type of plug. My explorer had it in the truck area.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Well, as mentioned above, you should have two already. In the centre arm rest console & cargo area.
senatorPOPS
Las Vegas, NV
2018 F150 - 1990 Bronco
Do you mean like a wall outlet you find in your home? if so, you need an inverter to convert the cars 12V DC to 120V AC or do you mean the barrel style 12V car outlet?
Tricky Dick
Dick
PNW
www.TD-Distributing.com
The 120v plug is only included with mid package and above iirc. You can get an inverter and plug it into the 12v port inside the center console.
Jmax
Plymouth
Explorer
Yes, I mean a 120v standard US plug. Like most of us in America have. I want to plug stuff into the outlet (heated blanket for the kids when it is a little chilly but we want the top or doors off, crockpot for tailgating, etc). But as I read more I am wondering if these inverters can handle the power needed. I don’t think it is as easy as saying “if it is 110-120v just plug it in. Many blankets show 150w max with a 120v plug but then go on to say they can’t be used on a power block. Anyone know the answer here?
donkeygoatrunner
jason
UT
2014 FJ Cruiser TTUE
There’s only one 110 outlet; it’s behind the center console. The outlet in the back is a 12 volt, just like the one inside the console.
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
I would run a fused power line from the battery to an inverter. Then a ground wire to bare metal as close to the inverter as possible. The size of wire is dictated by the power draw of inverter you need to run. I think you could get one under the seats or behind the rear passenger quarter panel.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I’m not running a heated blanket or a crockpot…but this does the trick for us in our BD with standard package…
PowerDrive PDI175S
JakeC
Jake
Dearborn, MI
michiganbroncos.club
2022 Badlands
Yeah, I’d definitely run some beefy dedicated lines for a powerful inverter if you have any hope of a heating blanket / crockpot. Those suckers require real power.
Bongo Fury
Bongo
Somewhere between point A and point B
2003 Ranger
OP from reading your posts it would seem your looking for an inverter. This allows you to convert your vehicles 12 volt DC systems power through the inverter to provide 120V AC power.
First thing for you to consider.
Take your time in understanding what you want to use it for and then what items you may additionally want to power up.
You do not want to undersize your power to the devices you intend to run.
I'd suggest by starting with youtube videos.
There's plenty of them out there.
I'll be doing the same with my Bronco once it arrives.
Pic below is my set up which provides outbuilding solar power and emergency backup power to the main house.
12v DC inverter to 60Hz 120 AC pure sine inverter
Again it's very important to take your time and learn about the system you want. It's not all that complicated once you grasp the basics.
Note: pay attention to the inverter you select.
Determine if it is "bonded" or "Non-bonded or Floating ground". Also I'd add look for a "Pure Sine" inverter to protect your devices.
Good Luck to you OP. If it seems too involved find a RV dealer/mechanic to assist you. They're pretty much standard features they deal with.
Ford Bronco 120v ac outlet ideas 1646399154834
Ford Bronco 120v ac outlet ideas 1646400359237
Roger123
Roger
VA Beach, VA
OP, you should modify your thread title to 120V AC vice the 12V you have there now.
Jmax
Plymouth
Explorer
Thanks for the advice, that looks intense.
Ill start looking up YouTube videoes. I am fairly handy but the conversions and understanding electricity will take a bit of education… I was going to run both positive and negative to the battery, but you are saying ground closest to inverter as possible, why? I am looking at a 1000w with 2000w peak but apparently that won’t do it for a 150w blanket. I’m guessing it is the heating coil technology where we run into troubles with blankets and crockpots. Weird, it’s not a microwave or drier…
Roll Sound
Hollywood
2021 Wildtrack 2DR MIC OW, 2014 KTM RC8R
