Dumb Question about 12v outlet
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
Do you have a post on how to do that? My F150s cig lighter is always hot, sure miss that on the rest of my more recent vehicles.
Was just looking into doing this and the setting is under BdyCM module, Power Point timout and power Point timeout s. Assuming one disables/enables and the other controlls the time out. As of right now I haven't commited the changes, but will do it later as I have some LED lights for the back that need no timeout and need to light up with remote start. This isn't documented yet in the master Forscan document/excel file.
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
@MNBigfoot Confirmed Forscan can disable the timeout, tested with the back 12V plug. The setting is the BdyCM under "power point feature" item, just set it to disable.
da_jokker
Jeep Wrangler JKUR
This changes the timeout for the center console 12v as well I assume? Unfortunately I need to keep the center console one on a timeout but would love to have that cargo on 24/7
willettj
Joe
2023 Ford Bronco
I had this working with the PowerPoint disabled for the brake controller in my Bronco when towing behind the RV. Now the setting still shows disabled but power point goes off immediately when ignition off. I even enabled it and the original default settings of the timeout don't work, it still goes off immidiately. Ford did some OTA that messed this up
GroovyGeek
Boyan
'23 Bronco BD
Were you ever able to resolve this? I am experiencing similar symptoms. Regardless of the time of the power point timeout setting, and whether it is enabled or disabled, the power to the 12V outlet in the back goes out immediately. This used to work fine, noticed that it does not work today, and coincidentally Ford pushed some OTA on me yesterday, not sure if this is related.
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
It’s not just the LED that’s still on, it’s also listening for commands from the remote. Probably still not much draw, but still.
Johnny Mo
Westchester County, NY
teachu2shoot.com
M-B GLE53 AMG, Ducati XDiavel, Jeep WK GC x3
I too can confirm this works - I used a vampire connector on the rear power port for the relay on my ARB Twin - I dialed down the on time so that it doesn't continue running with such a huge draw after the ignition is turned off. Mine stays on for only 25-30 seconds now.
willettj
Joe
2023 Ford Bronco
I will check mine again when the wife gets home with the Bronco.. haven't had to use it in awhile but last time I suspected it was being disabled due to battery being low, however the Bronco wasn't saying anything about low battery and was starting.. but charging the battery seemed to resolve it
