vrtical
Doug AI
GSMNP, TN
Fords
I have been posting pics here and there but the complete install is finished and functioning.
1) Installed frame Horn reinforcement brackets.
2) Installed Turn Offroad winch plate and Warn winch with Factor55 upgrades.
3) Installed and wired up Stinger 500amp relay which is triggered from uppfiter switch.
4) Added FP cover to finish out the job.
5) grab a beer or 3 😁
Ford Bronco Warn VR EVO 10S Winch Installed 1000004241
Ford Bronco Warn VR EVO 10S Winch Installed 1000004247
Ford Bronco Warn VR EVO 10S Winch Installed 1000004257
Ford Bronco Warn VR EVO 10S Winch Installed 1000004258
Chrome_Pony
Chrome
The Great Land
Only note I have would be to paint over those brackets. Mine were coated, did you order them raw?
DewarT
Todd
Looks good- just picked up a 12S to install over the long weekend.
vrtical
vrtical
Doug AI
GSMNP, TN
Fords
They will be mud caked by next weekend lol
Y2KFirehawk
PA
2022 Bronco Wildtrak
The FP cover is 👨‍🍳 💋
In addition to coating/painting the raw brackets to avoid corrosion, I'd consider changing the power lead zip ties to the intake tubing. The engine will move and you won't want that cable moving or rubbing.
vrtical
vrtical
Doug AI
GSMNP, TN
Fords
I may fab a bracket still figuring out where to mount it on the pos side there is nothing there so the wire is free standing and I used the zip ties just keep it farther way from the turbos/engine heat. Also the wire wont rub on anything made sure of that one.
GI_Jo_Nathan
Jonathan
Nice! I bought that Turn Offroad winch plate. I didn't like how far out it stuck. Probably going to list it for sale for cheap.
gmac71
Glen
Vancouver
'20 Ford Expedition; '21 Ford Bronco Badlands 2dr
hi looks good...which horn brackets did you get?
vrtical
vrtical
Doug AI
GSMNP, TN
Fords
Yes but the only other two solutions is run a high mount (which is bad) and a complete new bumper system. I like the OEM bumper so went this route, doesnt look as bad with my Project X lights on there.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Curious - (planning on doing this myself) - How much did the front end sink before and after?
Dads_bronze_bronco
Also, can you share a side view showing the finished approach angle?
How is your front camera view? Do you need to relocate it?
vrtical
vrtical
Doug AI
GSMNP, TN
Fords
After install it only moved the front 1/8", but I am running preload collars and a braptor has some pretty significantly stiffer front springs with the weight and 3.0L.
Approach angle is not affected on my rig at least, but the bottom of the plate is 27 3/4 from ground.
Front camera view is actually not bad, but I do have a M2M camera relocation kit, just haven't put it on yet, going to see how it is next weekend first. My sight lines for left/right tire location are good.
Tricky Mike
21 Bronco
Looking good. I have the non S and it's been good to me. The range on the wireless remote keeps getting shorter though, maybe the battery is weak.
vrtical
vrtical
Doug AI
GSMNP, TN
Fords
I have the wired version not even sure if they have a new kit for these or not, need to dig.
