- Joined
- Oct 17, 2021
- Threads
- 46
- Messages
- 1,159
- Reaction score
- 2,717
- Location
- Central North Carolina
- Vehicle(s)
- 2021 Base/2DR/2.3/MT & 2023 Model S Plaid
- Your Bronco Model
- Base
- Thread starter
- #1
Bronco6G friends,
Some of you may have seen me post 0-60 & 1/8 mile times throughout this forum, but figured I would start my own thread. Wanted to have a place to post my ongoing results as I add more performance mods to my Bronco. Why do this? I mean, it's an off-road vehicle, not a drag car; right? Well...I do it because It's fun and I enjoy seeing what I can eke out of this platform and the little 2.7L engine. Iām all about making a quick off-roader
My Bronco is a 2022 Big Bend Sasquatch 4DR Soft Top with the mid package. It has the modular front bumper, added factory skids plates, NFab rock sliders, and ACFab shock skids. In a nutshell, I have no plans to make my Bronco lightweight as I do wheel the vehicle and put the added protection to use.
Current list of performance modifications:
With just the S&B air filter and using 88(E15) or 93 octane I would consistently hit 0-60 in the 6.5-6.7 sec range. When I added 6 gallons of E85 for a E30-ish mix, I would drop down to 6.3s and 1/8 mile in 9.46s (would be closer to 9.39-9.40, but let off too early)
Today I installed my Ford ProCal device and managed to drop my 0-60 to 5.69s. This was with 93 octane. I also did the 1/8th in 8.99s and 60 ft in 1.95s (Faster than my old 93 Mustang 5.0 w/FBO
The Bronco now wheel hops off the line in 4A...wasn't expecting that.
All runs done in Sport mode + 4A + ATC off + 2nd gear launch.
Still have Palm Beach Dyno in my sights
They were able to achieve 0-60 in 5.34s. This was in a 2021 WT with the top, spare and doors removed + JB4 @ Map 4 with E30 + Exhaust
Video from PBD showing how they achieved their 5.3s run.
[UPDATE 1/7/24]
Installed Injen CAI and Turbosmart BOV and ran again.
Did my 0-60 and 1/8 mile with the addition of Injen CAI and Turbosmart BOV. No real improvement flat out, but in day to day driving I noticed a solid improvement in midrange power. I ran it a few times and the were all pretty similar. Think iām gonna need more boost plus an intercooler for it to make a substantial difference.
[UPDATE 1/13/24]
Today Iāve been driving around with the RaceChip set to level 3 and the Bronco feels great. I decided to give this setup a run since I had a nice piece of road away from civilization.
This time I launched the Bronco in 4H instead of 4A. The launch was more violent and I experienced more wheel spin, though it still pulled hard off the line. Think Iām gonna drop the air pressure a bit and not launch so hard next go around to see if it improves my times⦠Anyway. The RaceChip was exactly what I needed. I donāt know how much boost it adds, since I canāt see the actual boost pressure w/piggyback tuneā¦
Regardless, even on this low setting I ran the times below:
60ft = 1.90s
0-60 = 5.32s
1/8 mile = 8.74s @ 77.32 MPH
1/4 mile = 13.84s @ 95.60 MPH
This was on a fresh tank of 93. Technically, these times are faster vs. Palm beach Dynoās run, but there was an issue with the 0-60 run being unverified within the app. Oddly enough, the 1/8 and 1/4 mile saw no issues and were verified. Doesnāt matter, I still have more to come so Iāll do it again. Still, these are BRaptor beating acceleration numbers.
[UPDATE 1/28/24]
CV Fabrication Intercooler and plugs installed.
āOfficiallyā beat Palm Beach Dyno 0-60...barely, but a win is a win
[UPDATE 2/4/24]
Was not expecting this, but was able to achieve 0-60 in under 5 seconds. This was in part by using E30 mix for fuel and getting a solid launch in normal mode without wheel hop.
[UPDATE 2/16/24]
Okay, so I've had some fun testing the Pulsar XT and Ford ProCal Tune combo. Still working on my standalone Pulsar XT review, but I'll post my results and thoughts with the two stacked together here.
Running 93 Octane + Ford ProCal tune & the Pulsar XT set to level 5 I ran the 0-60 time below.
The best run I had was 5.04s, but I experienced wheel hop.
Same setup as above, but with a mix of E30 fuel.
4.8 Seconds! Crazy for a five thousand pound shoe box on 35's
This combo is faster vs. The RaceChip S and ProCal tune, though I would rather daily the RaceChip since it doesn't retard the timing as much as the Pulsar XT.
I won't daily this combo, but wanted to share my experience with the two stacked together.
Got even better times, thanks to the cold weather
[UPDATE 2/28/24]
Successfully installed a custom tune from ZFG Racing and HP Tuners. More to come.
[UPDATE 3/8/24]
Finishing up my 93 Tune. Took 5 revisions, but now she runs under 5 secs with just 93 in the tank. I'm thinking I'd see in the 4.6-4.7 range 0-60 with E30 in the tank. Not gonna wait and try, as I'm moving straight to E85...very soon
UPDATE 3/16/24
First 12 Sec Ford Bronco 6G (Dragy Run)
UPDATE 3/29/24
Dyno time
Best run thus far with all of the mods and the spare tire removed:
UPDATE 8/25/25
More performance goodies coming in 2025/2026
- HP Tuners MPVI3 w/ZFG Racing Custom Tune
- CV Fabrication Intercooler
- CV Fabrication High Mount Intercooler (Newly installed)
- CV Fabrication 3" Cat back Exhaust
- CV Fabrication 3" Catted Downpipes
- CV Fabrication Charge Pipes
- Injen Evolution Cold Air Intake System - EVO9301
- Turbosmart Kompact EM VR19 Dual port BOV
- NGK 95605 plugs gapped to .028
- Pedal Commander
- J&L Catch Can
- GPE Ported Intake Manifold & Throttle Body
- Boomba Racing Intake Manifold & Throttle Body Spacer
- Injen cold air intake - Installed 1/1/24 (Upgraded from S&B Air filter)
- CV Fabrication Intercooler Installed 1/28/24
- Turbosmart BOV (Plumb back)
Installed 1/5/24 - RaceChip S model (Install on top of ProCal) Installed 1/13/24
- NGK 95605 plugs gapped to .028 Installed 1/28/24
- 3" CV Fabrication Cat back exhaust - Installed 2/20/24
- HP Tuners w/ZFG Custom tune - Installed 2/28/24
- CV Fabrication Downpipes - Installed End of April
- CV Fabrication Charge Pipes - Installed 6/05/24
- J&L Catch can - Installed 6/10/24
- GPE Ported Intake Manifold - Installed Oct 24
- GPE Ported Throttle Body - Installed Sept 24
- Boomba Racing Intake Manifold Spacer - Installed Nov 24
- Boomba Racing Throttle Body Spacer - Installed Nov 24
[UPDATE 1/7/24]
[UPDATE 1/13/24]
60ft = 1.90s
0-60 = 5.32s
[UPDATE 1/28/24]
[UPDATE 2/4/24]
[UPDATE 2/16/24]
[UPDATE 2/28/24]
[UPDATE 3/8/24]
UPDATE 3/16/24
UPDATE 3/29/24
Dyno time
UPDATE 8/25/25
