dougcjohn
Doug
Iowa
‘24 F450 Limited, ‘25 Bronco Raptor, ‘16 Smart Fortwo, ZX12R
All 3 above posts were informative and helpful in gaining a better understanding of the Bump-stops.
Have a much better understanding of the manufacturer, materials and product now… Thanks!
These do sound like a great alternative for Street to Aggressive Recreational usage! My use is street to Ag fields & Pastures with waterways… I can easily exceed travel and hit bump stops with a little additional speed.
Price is moderately higher than my first expectations, although as mentioned they’re within same zone as other products. When I read 3D Printed, I typically jump to the lower price scale. After hearing the manufacturing process, and equipment involved… these don’t sound like your typical 3D print part.
With the 8 yr warranty, that should get you past any 3D material concerns holding up.
I’ll put these on my “List” for probably Fall.
MongoTheBronco
Emma
Fayetteville NC
fordraptornation.com
2024 Bronco Raptor & 2025 F-150 Raptor
100%!!
The second "3D printed" pops up in any way it immediately raises red flags.
3D printing is used due to the internal geometries, air passage ways, ramp cone, and other small features being next to impossible to create using injection molding.
These custom pellet extrusion machines were constructed to provide the best of both worlds. Incredible and truly industrial grade materials and the freedom to manufacture such a complex part.
Most see these as a simple rubber stop when they're much more complex
Sir915
Shawn
El paso
2023 Bronco
Dang it!! now i want to try these but thank your for bringing these up very cool !
DarthLincoln
Chuck
Northern California - Contra Costa County
1999 BMW M coupe, 2023 Ford Bronco Badlands 2dr
100%!!
Czinger is making hybrid hypercar with 3D printed chassis components. 3D printing technology is certainly capable of making amazing things if you do it right.
swamp2
These look very promising. Great warranty too.
Spooled
Republic of Texas
Raptor, Model 3
I just installed a set of the front bumps. I'm jumping it Saturday so they will get put to use quickly.
swamp2
Cool. They are very pricey but do look promising. Keen to hear your feedback on hard use.
Spooled
Republic of Texas
Raptor, Model 3
they are pricey for what they are but first impressions are good. Much better controlled bottoming out at the front. I’m hoping someone here can grab a video
swamp2
Rears?
TheLawnDart
TheLawnDart
Austin
Las Cruces
FJ Cruiser, Subaru Forrester, Hyundai Palisade
I have a lot of video underneath my bronco of both the front and rears hitting. Some from the outside too!
Spooled
Republic of Texas
Raptor, Model 3
fronts only. I don’t experience any harsh bottoming out at the rear. I think the added travel the rear has vs the front from the factory helps a lot.
Spooled
Republic of Texas
Raptor, Model 3
So, I ran a short course 3 times and there's a jump at the end that you can definitely overcook. I've ran this course before so I know the limits. I can safely say there is significantly better bottom out control at the front. Before it was quite jarring. It would slam the bumps then bounce back up. Now, I would say the last 10-15% of travel is cushioned before bottom out. This makes it smoother as the rebound is not so instant.
Ford Bronco Upgraded Bronco Raptor Bump Stops (3D Printed)!! Image - 2026-08-10T092821.805
Spooled
Republic of Texas
Raptor, Model 3
Sherpa11
Jay
West Hollywood
77 bronco, 21 first edition, 24 bronco raptor, 09 H3 alpha, 04 LR discovery
They seem pretty appropriately priced for the market. Sumo springs are more expensive. The only other comparison on the market is the Foutz hydro bumps. What price would you expect them to be?
I would say about 100-150 a pair max. especially with not much info on how they're made and specific materials
