Wolfbox Rear Camera Mount Location - Where's Yours?
Herbie
Alex
Cleveland OH
2022 Badlands
Yes, everything in the rear is stock. The mirror only shows a portion of the image that the camera captures. You can scroll it down or up (see pics) so you can line it up pretty well with the rear window. When I play the recording back I see the spare and a large black band on the top. I've got a 2 door. Don't know what the view would be like on a 4 door arranged this way.
Now it looks like my view. Was just wondering where your tire was hiding. We have our cameras in the exact same place.
South Jersey
2002 Olds Bravada, 97 Rav4, 2024 2D BD 2.3L auto
My camera is aimed up pretty high, the pic with the tire is scrolled down to the bottom of the image.
Think that the roll bar on the 2 door and 4 door are different distances from the rear.
jayr1959
Jay
Delaware
2015 Jeep JK 2DR 2008 Saturn Sky Redline
Just mounted the camera Inside. I had it under the factory camera on the stalk but in rainy weather I could not see anything.
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? IMG_0569
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? IMG_0568
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? IMG_0582
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? IMG_0570
DaveInSA
Seguin, Texas
2025 F150 Lightning Flash
I just moved mine to the top of the third brake light... Better positioning, but it sure bounces now... hmm..
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? 1739154484699-88
bennyxbronco
N
Toronto
2024 Bronco
Mine is mounted inside in the rollbar nook as well and the picture is good as far as I am concerned and I don't have to worry about bad weather. I know the OEM backup camera always gets mucky when the weather is bad so I didn't want to have two bad cameras doing that. Picture of mount and view from mirror below.
This is clean, what brand/model?
Ninjak
Miami
WolfBox
Florent
LA
2021 2dr Bronco
Thank you all for your sharing! We're so glad to participate in your journey! Let the adventure stories be told!:rockon:
Herbie
Alex
Cleveland OH
2022 Badlands
Canonman11
Tim
Tampa, FL
Mounted mine under the third brake light. I have an extension on the third brake light to bring it up a little farther above the tire.
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? IMG_7158
LevelSeven
Lee
MT
Bronco - 7MT
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? IMG_0922
This is working great for me.
Make sure you put heat shrink tubing over the rear camera connector. It is not waterproof.
And big thanks to WolfBox customer support who had a replacement sent out asap.
With my setup you can also have a ‘rock crawling’ mode by flipping it down with the included bracket. No need to re-mount. It swivels.
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? IMG_0923
Tye
Tye
San Francisco
Porsche GT3, Landrover Defender V8, BMW X3 Msport
my setup im currently finishing up. Note, im using an acumen mirror and a flush mount adjusrable camera
Ford Bronco Wolfbox Rear Camera Mount Location - Where's Yours? 54461323-FC84-4248-9F32-D1860706EA80
tobands
2022 Bronco OBX , 2024 Edge ST
thats the way i installed mine.. The lens stays alot cleaner
haynstyle
Kawika
Delaware
22 Bronco Outer Banks
Where are you mounting this? Love to see it finished
alihenry87
Ali
Illinois
2024 Bronco
This is a good idea. Are you able to zoom in the instance of getting a license plate behind you? Was it easy to hide the wires?
