Wolfbox G900 TriPro Camera Review
jtgensler
Jamison
Clarion, PA
2022 Bronco
Wolfbox selected me as the recipient of their August giveaway for a "blind box"
When I received the package, I was pleasantly surprised to see that it was a G900 TriPro dashcam setup.
For those unfamiliar, the G900 replaces or covers your OEM rear view mirror & adds a forward facing dash cam, along with a rear facing camera & a bumper cam.
The kit includes a hardwire option or a 12v outlet plug.
I chose to use the hardwire kit & installed both the main fuse tap & the "parking mode" fuse tap.
I highly recommend watching the video from Stickerfab on YouTube to help with wiring it up.
I also chose to spend $20 & get the OEM replacement bracket, so that I could remove my OEM rearview mirror entirely instead of holding the camera over the mirror.
Ford Bronco Wolfbox G900 TriPro Camera Review OEM Replacement
The wire harness from my mirror fits neatly in the plastic trim pc that covers the factory safety camera.
I happen to have a high/lux package Wildtrak, so I did have an OEM front bumper camera, which I moved out to my fairlead earlier this year since I was catching mostly just a view of my winch.
So I mounted this camera right in the opening of the OEM camera - I did have to modify the small plastic bracket by cutting the OEM housing off.
Ford Bronco Wolfbox G900 TriPro Camera Review Front Wid
Ford Bronco Wolfbox G900 TriPro Camera Review Front Camera
For the rearview, since I have a soft top, I chose to run my wiring out the passenger side of the windshield, down the wire chase under the door sills & out to the tailgate.
I mounted my camera on the license plate bracket, so I'd get an unobstructed view from behind.
Ford Bronco Wolfbox G900 TriPro Camera Review Rear Wid
Ford Bronco Wolfbox G900 TriPro Camera Review Rear Camera
I haven't had a chance to use it offroad yet, but I do know from experience with the OEM camera that having a bumper cam is a huge assist offroad. It makes it so much easier to choose a line & be confident in where you're heading.
And it's a gamechanger on breakover when your nose is pointed up at the sky....
A few views of the camera in action. You can have all three or any one displayed.
It also has very easy voice commands like start recording, stop recording (for you know, when you need to do things you don't want on film), allows you to take still pictures with a voice command & lock a video if an incident occurs.
Ford Bronco Wolfbox G900 TriPro Camera Review Bumper Cam
Ford Bronco Wolfbox G900 TriPro Camera Review Wolfbox + OEM
much thanks to Wolfbox. We have the same setup installed on my brothers F350 - they're super convenient & a quality dashcam.
I'd highly reccomend as a dash cam, & if you don't have an OEM front camera, it's definitely worth considering for offroad use (& parking lol).
Wildfire1
Paul
Nfld, Canada
1993 GMC 4X4 / 2012 Mustang convert
I put the same setup in 2 out of four of our vehicles. It’s a great system. Hard wired both so I could have parking mode and using their optional rear view mirror setup is a must. Doing that eliminates the bulky rubber band straps And makes the unit look as if it came from the factory like it.
If you really want to make the unit work at 100% then add the inexpensive lens filter over the camera. Using it will get rid of any reflection of the dash in the footage. 100% satisfied with both units. I’m convinced it’s the best dash cam that’s out there.
Both of my Wolfbox g900 tripro’s cab versions were purchased by me so my review is as honest as it gets.
I’d have one in the Bronco but I put a Blackvue system in it two years ago which is also good but nowhere as good as the Wolfbox so I can’t justify purchasing another Woldbox.
Folks. This is the dash cam you need. Honestly.
Ford Bronco Wolfbox G900 TriPro Camera Review IMG_5800
Ford Bronco Wolfbox G900 TriPro Camera Review IMG_5802
Ford Bronco Wolfbox G900 TriPro Camera Review IMG_5801
Ford Bronco Wolfbox G900 TriPro Camera Review IMG_4083
Pokey_Cacti
Dan
Prescott, AZ
2024 2-dr Black Diamond
Where did you pull your power from?
Johnny Mo
Westchester County, NY
teachu2shoot.com
There's really only 2 options...dongar adapter and pull from the existing mirror connector (alot to bury in a small trim panel area) or use the hardwire kit and go direct to fuse panel with a jumper fuse.
Pokey_Cacti
Dan
Prescott, AZ
I went to the fuse panel...139/USB charger for the constant 12vdc hookup and 22/image module for the 12 on ignition/accy hookup with the Wolfbox accy wiring kit. I took the stock mirror down and used their dash hookup for that, although I needed to get four 2mmx0.40 pitch screws for the back of the mirror four screw mounts for that. Not sure why they didn't include that. This is our 2nd TriPro900, we also have one on our RV. They're really nice! btw we have a '24 Black DIamond.
