Windshield Ice Accumulation
Gregory61
Gregory
New Hampshire
2024 Bronco; 2015 Odyssey
As my second winter with a Bronco starts in Colorado, I am reminded of an issue I was hoping Ford would have addressed. I don't know if anyone else has experienced this issue(not sure how you couldn't) but the tips of my windshield wipers do not defrost. Where the sun sensor sit there is a gap in the defrost vent. This leads to the tip of the drivers windshield not being heated and an accumulation of ice on the last 2-3 inches on the blade. The ice builds under the blade and lifts the blade so only the few inches closest to the mount make contact with the windshield. Does anyone else have experience with this and have any suggestions? I have pre-ordered the Gatekeeper heated windshield wipers. I had reached out to Ford Development with no response last year. I am also running the stock blades and have not used any RainX or repellent on the windshield Thanks!
Same. 🤨
B22-2023
Houston
Colorado guy here as well and that has been one of my bigger gripes driving the Bronco in the winter. I usually have my defrost only on full blast and still get issues with the ice accumulation.
Well, if there is throwback feature to Gen 1 Bronco we didn’t need, this is it!
buffhorse
Ford Bronco
how do you like the gatekeeper wipers? Are they worth it? Was the install easy?
SkiSquatch
Neil
BostonArea
2023 Bronco
Since there's been no followup on this, I went and purchased a set of thermalblade heated wipers. They are the ones Gatekeeper resells, but Gatekeeper also includes a bracket for the extra money. I 3d printed a bracket (if anyone wants he STL or the tinkercad info, let me know.
Kind of a pain to get the wires through the Cowl, and the passenger side I had to add another 'drain hole' that I ran the wire through.
Just getting around freezing in my part of the north east, so no reports yet. I'll post when I have more feedback about them. Some pics of the install, needs some cleanup this weekend.
Ford Bronco Windshield Ice Accumulation 69ED1811-1CF0-4233-9DCC-0BD9D78AA4CE_1_105_c
Ford Bronco Windshield Ice Accumulation 0D1B19D9-16CF-49CD-A3AB-E83D6D9C2DD0_1_105_c
Ford Bronco Windshield Ice Accumulation F8E912F9-A62D-4C38-888F-B4A8C78A6E23_1_105_c
  • Like
Reactions: Fly
Footer
2023 Bronco
Ran the Everblades on my FJ for years, did an admirable job. One of the drawbacks was replacing them once they were shot, $60 per blade.
Any reason you couldn't run these to an OEM AUX switch ?
SkiSquatch
Neil
BostonArea
2023 Bronco
Those would be any easer install, simpler wiring harness. But the replacement thermalblade squeegee is $24.99.
23OBX2.7
AB Canada
2023 Bronco
What a great solution!!
SkiSquatch
Neil
BostonArea
2023 Bronco
So no complaints so far. Had some snow and ice overnight this week and seems to be working well. Remote started the bronco and wipers were pretty clean when I came out. I haven't driven it in a big storm yet, so that's the next real test. I do think the warm squeegees are cleaning my windshield well. So no issues so far.
Looks like some storms coming in next week, I'll report back on driving in a storm if that happens.
SkiSquatch
Neil
BostonArea
2023 Bronco
So I ran them all winter, drove through some really bad storms that I had to stop and deice my headlights. The wipers were great, no accumulation. And when I remote started in the really cold mornings or with snow/ice accumulation, there was no sticking to the windshield and the warm blades worked well in the morning. So no issues and it was worthwhile.
jclark
Jeanette
Mid-Michigan
I ordered the Gatekeeper kit and had a couple of follow up questions for you - any issues with the 18" size blade in the kti versus the 17" OEM on the Bronco?
I know these are a pretty straight forward install, but I had my rig at the shop for some other mods and just had them do this at the same time. My Gatekeeper kit didn't come with the adapters for the wiper arms and had 18" blades. I tried to have Gatekeeper send 17" blades when they sent the missing clips - but they claimed they've had no "issues reported" and claimed the 18" blades would work.
As long as I was paying shipping, I also ordered an extra set of blades to have - also heated. Do you run the non heated option in warmer temps or just keep the heated ones on year around?
SkiSquatch
Neil
BostonArea
2023 Bronco
Since I went through Thermalblade, I have the 17's. Looks like there's room for 18's, but I have the same perspective you do. I got the non-heated ones on about a month ago, swaps quickly. Thermalblade sent me extra wire covers as well, so good to have those extras. I'll order another set of heated onces in the fall just to have on hand.
jclark
Jeanette
Mid-Michigan
Circling back to pass along that if you are interested in a heated blade option, I'd suggest to order direct from ThermalBlade. The GateKeeper kit is an attractive option as it is promoted as fairly turnkey and everything you need.
Based on my experience, however....
  • At the time I ordered, they were including 18" blades. OEM is 17". ThermalBlade provides 17" for the 2021+ Bronco when you order from them directly.
  • My kit was missing the A3 adapters. When I contacted them for the missing part, they sent me 2 different versions of the adapter (so visually, they didn't match). As a side note, I had also requested 17" blades to be included in case there was an issue with the 18" when installed, and GateKeeper declined that request.
  • The wiring harness that comes in the kit, which is from ThermalBlade is not long enough to install per the instructiosn to the location for the GateKeeper mounting bracket (at least not in a Bronco Raptor).
The 18" when installed did hit my cowl. Not to say all installs will, as GateKeeper said they haven't had anyone report any issues - but mine did.
Winter weather will confirm how well they work for the issue I'm trying to fix - but if you are considering this as an option, know that ThermalBlade is the source of the products and make a decision on your source based on the pros and cons of a kit versus ordering from ThermalBlade.
HighVelocity
Big Sky Country
Pinto
