Window Wobble when opening and hitting bumps?
jnew71
Georgia
Bronco Black Daimond
Sorry if I missed this in a previous post - I looked but didn’t find the answer.
Has Ford fixed the issue with the window wobbling when opening and rattling when hitting bumps? I was under the impression it was to be fixed in Q4 of last year. I’ve tried moving the bolts at the bottom of the affected door with no luck.
Jazer
Jessica
2.7 OBX
My dealer was able to correct mine with an adjustment over a year ago. I had them do it so it would be notated in case it got worse or god forbid the window broke from it at some point. It fixed it but It has since started shimmying again, tho it is very minor in comparison to how it was originally.
Sgt Badlands
Joe
Midwesr
Look up some videos on YouTube. You can adjust the window with two bolts on the underside of the door. It’s a frameless window som some bit of wobble is expected.
jnew71
jnew71
Georgia
Thanks - I’ve done this. It didn’t work. It was mentioned before that Ford engineers were expected to have a solution by now - was hoping they delivered one but that appears to not be the case. Thanks for feedback
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hey there, Jeff! Should you need further assistance, can you please send me a PM with your VIN and dealer name/location so I can look into this window misalignment concern for you? I'd be happy to see what I can do to assist! To send a private message, just click on our username and select "Start Conversation".
No, it really hasn't been fixed.
The adjustment can help - but won't eliminate it entirely. One of my biggest complaints about my Bronco is I can't drive with the windows cracked - it's either all the way up or down.
BigBlue7
New Jersey
‘23 Black Diamond Sasquatch
Did the window adjustment from under the door and helped for a bit, but back to wobble. Definitely not a permanent fix
Tilzbow
NV
GM Sierra Diesel Pick Up
It’s a frameless window so it’s going to wobble. Like the previous poster said, you gotta have it either all the way up or down on bumpy roads like a washboard dirt road. It’s pretty annoying but I don‘t think there’s anyway to get rid of it entirely since were dealing with an unsupported window when it’s not entirely up or down.
