Window Close Reset
Red
CBUS
Race E Bronco. Wile E Mustang
Can the window close function be easily reset to adjust ?
(My drivers window would seal best if I could back it off a mm or 2)
TIA,
R3
PWillette
Parrie
Maine
Try the reset procedure...with window fully up press and hold the window down switch and continue to hold for 5 seconds. Release then hold the window up until fully closed and continue to hold for 5 seconds.
Pops
North of Seattle
2025 2-door, Sas, Mid Pkg.
I am curious about a fine point of this that i've read some people say needs to be done:
Hold the window switch only to the half-way point and not all the way to the automatic position?
half-way worked for me, but didn't try the automatic position while still holding.
NMWildtrak
Keith
Rio Rancho, NM
2022 Wildtrak
I've repeatedly had to reset my windows. The reset process works, but its a royal p.i.t.a to do over and over again. What causes the calibration to go?
orion
Jeremy
17' F-250, 17' Explorer
VirginiaHeritage
Frank
ā€˜25 Bronco HE
My original attempt was full switch pulls and it didn’t work after several attempts. Then found a YouTube vid that explained not to do the full pull. Next attempt worked.
This was on my ā€˜25 with auto-open/close windows. Not sure if it applies to everyone.
I’ve had to reset my passenger back window at least 3 times. I think it’s just friction. I clean the window glass edges and the seals, and it tends to be fine for a couple of months. I get a lot of dust exposure on my neighborhood road.
GA2Dr
Marietta, GA
2024 Bronco 2 DR 2.7
I've never had this issue. Maybe because I did the window adjustment linked in this post...
https://www.bronco6g.com/forum/threads/window-getting-caught-when-opening-door.24948/post-1172539
I've adjusted my windows and still have had this happen, though only twice since I've had it. Both times the passenger door. First time it un-f**ked itself without me having to reset it. Recently I did the door seal upgrade and about a week later it happened again, only this time it did not resolve itself and I had to do the re-learn procedure. Hopefully it's doesn't keep happening regularly.
