How to reset the BMS system?
broncobase1
Lincoln
22 Bronco Base
How do you reset the BMS system on these Broncos? I used to be warned 30 minutes before it was time to pull over to poop. Now I don't get warned until after its too late! Where is the sensor for this system? Hopefully its just a software fix.
RobWTX
Rob
Did this on mine, worked after I put in a new battery (copy paste from another site)
The "High Beam & Brake" Manual Reset
This method recalibrates the system to recognize a new battery or a full charge state.
  1. Get in and Close the Doors: Sit in the driver's seat and ensure all doors are fully closed.
  2. Turn Ignition to ON: Press the Start button without your foot on the brake. You want the electronics on, but the engine should not be running.
  3. Flash High Beams (5x): Pull the high-beam stalk toward you (flash-to-pass) 5 times quickly.
  4. Press Brake Pedal (3x): Immediately after the 5th flash, press and release the brake pedal 3 times.
  5. Wait for the Confirmation: Within about 10 seconds, look at the battery icon on your instrument cluster. It should flash 3 to 10 times.
    • Note: If the battery light doesn't flash, the sequence didn't "take." Cycle the ignition off and try again, ensuring you do the steps in one fluid motion.
PWillette
Parrie
Maine
Plus rub your belly and pat your head, then do the hokey pokey
Valhalla
Valhalla
Chattanooga Tn
OHHH I like the Hokey Pokey!!!
