Wind Noise and the Light Bar
Canyon Coolers
Jason
Flagstaff
canyoncoolers.com
2002 C5 Corvette, Dodge RAM 2500, Sprinter Van 2500
I recently installed the Ford hood deflector, to protect the wind$hield, on my 23 Wildtrak, soft top. I noticed the cab seemed allot quieter, and it wasn't all that bad before. Do those of you with the hood deflector have any noise complaints ?
I want to add a large light bar up top but was fearful of creating a ton of wind noise.
So the real question is who has both the hood deflector and a large light bar up top ? Any complaints.
Ford Bronco Wind Noise and the Light Bar 20230306_104412
Ford Bronco Wind Noise and the Light Bar 20230306_104404
smonroe111
Stephen
Dallas
Chevrolet Tahoe
Watching
BigRed13
US
Super Duty
Interested also. I like the wind deflector, but have heard the opposite of people complaining of more wind noise coming from the deflector.
DUSTYcazOREGON
Craig
I have the same hood deflector and yes, it does a good job of tossing wind and debris up and over. I also have the Rigid OEM light bar. I have no noise caused by the light bar. I believe the first one's that came out did but with the fins on the back of the newer version....nothing (at least up to 70 mph).
Ford Bronco Wind Noise and the Light Bar InManCave2
DUSTYcazOREGON
Craig
The deflector IMO causes no wind noise. Some here have posted photos before and after...the difference in bug splatter and believe it has saved them rock chips too. I see no additional wind noise whatsoever. Also, if your hood flutters some, screw out the rubber bump stops for your hood.
KABQ
Aaron
Albuquerque, NM
I also noticed less wind noise after installing my hood protector. I'm thinking a wind deflector for the rack would help too, but I don't want to spend $200 for the Bad Ass Tents one... Any other options out there (other than making one)?
Basically any light bar is going to make it louder, but perhaps not quite AS bad with the hood protector to help.
ChipM
Chip
Warrenton Va
17 4 Door SD, 00 4 Door SD, 65 Fastback
I have the RTR light bar and wind noise after intall was increased noticeably, BUT the hood deflector fixed the issue. Soft top at 75 to 80 mph is no longer an issue.
HeHateMe
San Antonio, TX
2020 Hyundai Palisade
Question about this light bar on the OEM roof rack as I'm considering doing something similar...
How do you go topless? 🤔
WakeSS
Georgia
2023 AGM Bronco Badlands SAS
I went the other way. Installed light bar and entire soft top was flapping. Added the hood deflector and that helped calm it down. It's still freaking loud though.
SillyPosition
Silly
Israel
None
It’s loud because of the soft top or the light bar?
And which top is that, official or bestop?
DUSTYcazOREGON
Craig
The light bar does not interfere with removing the two front roof panels. To go completely topless (the rear section of the top off also)...requires removal of the OEM roof rack.
HeHateMe
San Antonio, TX
Yes, I've got that.
I meant more so in how do you remove your oem roof rack *and* light bar? Really, the light bar (I've removed my roof rack)...?
Does it have an accessible disconnect? Or... Does it also mount to the accessory panels when the roof rack is off (or does it *only* mount to the roof rack)?
Thanks for your help!
DUSTYcazOREGON
Craig
Yes, I've got that.
Yes, I've got that.
The light bar and it's brackets are mounted to the roof rack. So if you remove the roof rack the light bar would come off with it. If this is your plan, then wire in a quick disconnect where the wires come out of the light bar before they go into the vehicle for wiring. In my case I have the overhead switch panel and their are detailed instructions in how to wire up this light bar. Note: the new instructions = you no longer need to drill a hole above the "A" pillar.
You can also remove the light bar with just 2 nuts and leave the brackets attached to the OEM roof rack.
The light bar attaches to the roof rack. In the photo you can see the brackets. I had them painted cyber orange.
If you decide to order the light bar through Ford, it's by Rigid, and you have the OEM roof rack, make sure your Dealer orders the right one so you get the correct brackets....brackets for roof rack mount. #M-15200K-BRRL The BRRL signifies roof rack mount (there is another # for brackets that mount when there is no roof rack.
Ford Bronco Wind Noise and the Light Bar RigidLTbarDon
Note you can see the bracket from the front and on the driver's side, you can see it from the inside of the roof rack...the bracket kind of wraps around the roof rack. (I do not have a quick disconnect on the wire...I probably should have but I never intend to remove the roof rack or light bar).
redvettx2
Tom
Scottsdale, AZ
05 Maserati Coupe GT,16 Jag F-Type S,65 Cobra 427
The cooling fins on the old light bars use to get harmonic vibration and whistle. I glob of silicone between them fixed it. I had a roof mount and bull bar mounted light bar on my jeep. Upper light bar was over kill and not needed. Bull bar mounted is all you need off road and bumper or pod lights. The wind deflector will cost you 1 to 4 MPG. The rigs are tested in wind tunnels to be clean as possible to the wind. That lip is catching the wind and you can see it pulling on the hood. Dragt costs you MPG. No way around that.
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
Which hood deflector is this. I see ford lists two of them on the site.
