Why No 33's Option on BD Trim?
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
Why can't you get the Coyote in the base Mustang? Why don't they offer the 7.3L V8 in the F150? It really needs to be engineered together for certain options and powertrains to work and be able to be warrantied. And yes, it's to drive people that want higher options into higher trims. Called capitalism ;)
DLipin
Don
Grand Rapids, MI
2020 F-250 Tremor
First think I plan to do it have the dealer swap out the 32s for 33s, then find someone with a bb that wants to swap grill and bumper with me:)
sanford
Ross
Columbus
Chevy Silverado, Subaru Crosstrek, Bronco
What brand/size tire is everyone think to upgrading their BD to? (without a lift)
KirchTX
Nissan
I don't know if it's 100% confirmed if a lift is needed to move to the 33"s without rubbing. I'm sure by the time my '22 is being built there will be a standardized package of needed parts figured out.
I like the RTR rims and I've always liked the KO2s. Plus Costco carries them when I need new tires down the line.
jdbronc
Houston,TX
Silverado 1500 High Country
And if you do happen to grenade the M190 (which I don't think is likely on 33's without a locker) the M210 with locker is available from Ford Performance for $1800 + new driveshaft and halfshafts, at least for the 7 MT ratio.
Could you elaborate on this? I ordered a non-squatch BB with rear locker and planned to upgrade to 33's after the 32's wear out.
dejones64
Dan
MN
Bronco 2-dr Black Diamond
Yea I fell for it. Started with a Base back in July, ended up ordering a Badlands in Feb.
RiverRat001
Jesse
Buffalo, NY
14 Fusion, 18 Grand Caravan, 78 F250, 81 CB750F
I was firmly in the mid&manual BD club... until that was nixed for ‘21. I’ve since ordered a high&manual BL (well played, Ford). Honestly though, when I think about it... I like the 360 camera and front sensors. The sway bar disco is the only thing I wouldn’t care to add aftermarket.
When spending this much money, I like that I’ll have quite a few bells and whistles to show for it.
I know everyone here just wants their perfect Bronco but depending on your needs, you could trade the removable roof for towing capacity, then the Toyota TRD Off Road vehicles start to make more sense. They generally match the capability of a Black Diamond and can be cheaper too.
Jr87mustang
Josh
Northern Cali
It sounds like you're asking for the Badlands.
No, I don’t want black interior, signature headlights, a beehive grille, or sway disconnect. Thats a 6k jump for 33” tires and a front locker, no thanks.
Mickey21
Mickey
Round Rock, Texas
2021 Ford Bronco Wildtrak (Race Red)
I wish we could order 33's instead of 32's on the Black Diamond.
...The Bronco is boasted as being one of the most customizable vehicles on the market, so why not give the customer the option to have 33's factory installed on this trim instead of only 32's...
Customizable, yes... It has to ship somehow, THEN you can change it. Seriously though, there has to be some limits on how many ways this can ship, there are already more than any other vehicle I can think of. Count our blessings.
Ford Bronco Why No 33's Option on BD Trim? 1618255346893
HPNQ420
Wauwatosa, WI
The front differential from the Squatch and Badlands is sold by Ford as an accessory in 4.46 or 4.7 gear ratios:
https://performanceparts.ford.com/part/M-3002-446BF
https://performanceparts.ford.com/part/M-3002-470BF
So, if you have a Big Bend or Black Diamond with the MT, and want to go to the locking differential of the BL/Sasq, the whole unit is available from Ford. It says you'll need half shafts and a front driveshaft as well.
My need for off-road capability is typically at construction sights (I work as an engineer for a high performance window company.) and forest roads (I work part time training police and SAR dogs how to track people.) My Xterra has always been enough, and typically I can even get by with the Golf Alltrack by being very careful about wheel placement. So the BD is more than sufficient, and I prefer the 265 wide tires for winter, which I see lots more than off-road. But if the Bronco gets me into recreational off-roading, the 4.46 axles of the BD will easily turn 33's for the summer, and I can add the heavier duty front differential.
If you are ordering an automatic, you'd need to change the rear to match 4.46 or 4.70.
Headsong
But I like the BD trim better!
And that's a LOT more than just a little money. And there's a couple thou of crap I don't want/need.
Delli555
Delli555
Massachusetts
GMC Acadia
Yep. That is why I am going BD.
I guess I can live without the other stuff. I guess the High Package is maybe the option I would like the option of having the most with the BD that we can't get with it. Anything else I want I suppose I can add later via the aftermarket and vehicled modification. That way it ain't all wrapped into a big monthly car payment that collects interest is the other positive in the equation for me.
Delli555
Delli555
Massachusetts
GMC Acadia
I would think 33 is safe for sure, and maybe up to 35. If you want bigger than that you are gonna need to make a bunch of modifications.
dgorsett
colorado
F250, Mustang, Explorer
You gave an excellent response to the question. I think however that the BD gets 4.46 w/ AT and MT. The BB gets 4.46 w/MT but 4.27 w/AT. So the only issue upgrading to M210 would be a BB w/4.27, (as with my BB :confused:), that ratio is not shown as available in a M210.
