Whine when letting off.
RhondaS
Rhonda
2023 Bronco Raptor
Unfortunately I did not get good news today. Apparently the cap that holds the differential carrier in had loose bolts - wiped out the entire assembly. The dealer has ordered the whole rear axle assembly with differential but…. Can you imagine? There’s none in stock so one has to be built 🤦🏻‍♀️ No ETA - he’s expecting some kind of time frame tomorrow.
I had zero vibration or noise except for the whine when letting off the accelerator around 35 mph. Heartbroken to say the least but extremely thankful there wasn’t a failure when I was driving 75mph on the interstate.
RhondaS
Rhonda
2023 Bronco Raptor
Talked to a guy last weekend, Has a whine too. He thinks its just Turbo whine when you let off.
Don't know if I buy that.
Knowing what I know now, I definitely wouldn’t buy that. But my noise was coming from the rear so nowhere near the turbo.
Bandit958
Bandit958
Larry
Bad Axe, Michigan
77 Bronco, 2021 F150 4x4 Sport
mine comes from in front of me.
JDL
Jon
Panama City Beach, FL
Jeep Gladiator Mojave, Badlands 2D on Order
I just purchased a new 2023 Badlands SAS last Thursday. Noticed the same noise when letting off the throttle - most noticeable around 35mph. Took it in yesterday and they’re replacing pinion parts today. Less than 500 miles. Fingers crossed they fix it right and replace all the necessary parts so I can enjoy my beauty.
Front or rear diff?
RhondaS
Rhonda
2023 Bronco Raptor
Did they solve the problem?
Purchased 6/8 - to the shop 6/13. They’ve had it since then. The rear axle assembly is “special order” been waiting since the 13th. Got a call this morning that it’s repaired and will be ready for pick up this evening.
JDL
Jon
That's great! Please let me know if YOU feel it is fixed! Mine only has 400 miles on it and I'm trying to figure out when to drop it off.
RhondaS
Rhonda
2023 Bronco Raptor
I’ll let you know after I drive it. My advice is to either have them order it now or get it in ASAP because the part takes 3-4 weeks to get to the service center unfortunately.
JDL
Jon
Good Advice!
Bandit958
Bandit958
Larry
Bad Axe, Michigan
Beginning to think its just a normal whine.
RhondaS
Rhonda
2023 Bronco Raptor
In my case - it definitely wasn’t “normal”. I’d say that the differential being destroyed internally due to someone failing to tighten the carrier bolts doesn’t constitute “normal”.
RhondaS
Rhonda
2023 Bronco Raptor
Completely fixed! No noise whatsoever 🙌🏻
JDL
Jon
That is GREAT!
