Whine when letting off.
Bandit958
Larry
Bad Axe, Michigan
77 Bronco, 2021 F150 4x4 Sport
Has anyone developed a whine at highway speeds when you let off the throttle, Only does it 50 mph or above, As soon as you touch the gas pedal
again it stops, Sounds like its coming from right under your feet. 2.7 with 10 speed.
SasquatchMansquatch
4 door basquatch
Maybe just the reverse load on the gears making it make that noise? I'm not sure exactly how it's implemented in our broncos, but on most vehicles, over a certain speed, the torque converter stays in a more locked up position when you let off the gas, so it would make sense.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there, I'd be happy to look into your Bronco's whine issue on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
Felix808
SRV CA
Possibly sounds like the coast side gear engagement in the rear diff due to improper diff setup. I would have it checked out.
Bandit958
Bandit958
Larry
Bad Axe, Michigan
1FMDE5CP5MLB02824 2021 ORDUS FORD, BAD AXE, MI 48413
Bandit958
Bandit958
Larry
Bad Axe, Michigan
Usdmmark
New Port Richey, Florida
GMC Canyon
Did anything come of this? I have noticed I have a whine between 15-25 miles an hour, accelerating or decelerating. Normal and sports mode. The only thing I’ve changed recently is I put a cat back exhaust on but wouldn’t consider it a drone, definitely a whine.
Bandit958
Bandit958
Larry
Bad Axe, Michigan
Yes any speed above about 52
C00TER
Christian
Tonopah
Could you look into why my bronco still sitting on the ramp for almost 2 weeks built and no holds. my F150 that I’ve owned since new has broken down with a bad O ring around the oil pump that’s a known issue per Ford service bulletins.
I need a vehicle to go to work so I can pay my bills, hence ordering the bronco 900 days ago to getting in front of the tired f150.
but Ford motor company is not cooperating nor communicating.
but I guess that’s par for the course when you’re ordering a vehicle from Ford Motor Company.
I know I don’t matter to Ford or the executive's
It’s obvious with the communication at corporate and the dealership…
Mud Dawg
Charlotte, NC
2013 Wrangler Rubicon
Yep. Typically pinion pre-load problem when it whines after lifting off….
RhondaS
Rhonda
I just purchased a new 2023 Badlands SAS last Thursday. Noticed the same noise when letting off the throttle - most noticeable around 35mph. Took it in yesterday and they’re replacing pinion parts today. Less than 500 miles. Fingers crossed they fix it right and replace all the necessary parts so I can enjoy my beauty.
Bandit958
Bandit958
Larry
Bad Axe, Michigan
Talked to a guy last weekend, Has a whine too. He thinks its just Turbo whine when you let off.
Don't know if I buy that.
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
Had my doors off yesterday and coming down the mountain I was hearing this when letting off the throttle, goes away with throttle. Definately coming from front end so doesn't seem to be rear diff or a u-joint going bad. Monitoring myself for now, kind of sick of going to the dealer.
Ford Motor Company
Dearborn
