Which 37x13.5’s?
22 Spyder
Fort Lauderdale
2024 Azure Bronco Raptor (DD),2022 Porsche 718 Spyder(weekend)
Nitto 38 x 12.5 Ridge Grapplers
Those fit without any rubbing on factory Raptor suspension? I'm a big fan of Nitto Trail Grapplers, only offroad tire I'll use.
JerryG
Rich
NY
Ford Bronco
I don’t know about the Raptor. On a Sasquatch with a 2.5” coilover lift it doesn’t rub
Johnkn
Maryland
'66 GT350, 68.5 CJ Mustang, B2, Viper, Pantera,TRX
I don't disagree with that either :) I just wish Ford would of done the OEM design a bit better with inset spokes because they will get tore up instead of just the beadlock.
Howdy,
I appreciate your actual MT experience vs advertised specs. So your MT ATs appear a little larger than advertised? My BR is one of my daily drivers and I’m not embarrassed to say that it will be 99% on road. I’ll probably do 7k miles a year with 99% only me in it.
Given my use, would you suggest the MTs over the 13.5 Toyo AT3s? (For my use).
I’m looking for a wider, beefier tire w/o sacrificing too much on-road drivability.
Thanks
MORaptor1
SW MO
24' Braptor, 25' Expedition SPP, 26' Durango Hellcat JB
Any braptor folks want to post up their 37x13.50 rigs? Please….p
Johnkn
Maryland
^^ OP here.
37x13.50s are now sitting in my garage, new wheels should be delivered Wednesday. I really wanted to stick with the OEM beadlock (capable) wheels but I wanted to loose the 12 lbs per corner with different wheels to offset the larger tire’s weight.
More to come.....
Bikeric
Tulsa
2022 Badlands LUX on 37's
Curious what brand and model tire you went with??
Johnkn
Maryland
Likely the lightest, high quality 37x13.50x17, the TOYO AT3.
Highly rated, and a surprisingly aggressive tread pattern in that size....
My Braptor is just one of my daily drivers, almost no off-road.
MORaptor1
SW MO
^^ OP here.
More to come.....
Wheel specs?
Johnkn
Maryland
Satin black RTR EVO6 17x9 +18 (~22 lbs vs 34 for OEM beadlocks)
Johnkn
Maryland
Out of curiosity why +18 and not 0?
The Braptor version of that wheel is only available in right now in +18.
I have a few sets of new, leftover from another Raptor project, high quality Bora hub centric spacers in 1/4", 3/8" and larger if I need to tweak offset a little, but the 16mm (.63") difference between stock wheels and the new RTR +18 wheels should keep the wider tires off the UCAs.....
thanks
MORaptor1
SW MO
Pics for sure!
MORaptor1
SW MO
Get wheels and tires installed?
Johnkn
Maryland
Not yet. My 5th tire arrived yesterday. It will likely be next week before install. I did a test fit in the EVO6 Wheels last night to insure no surprises.
More to come
MORaptor1
SW MO
I ordered my wheels.......zero offset like i have on my F150 raptor.....just waiting to see how your tires fit before i get those ordered. 2" front level next week too.
