Wheel fitment between 2024 and 2025.
kdr2824
Kris
Austin, TX
2025 Bronco OBX
Dave2020GT
El Segundo, CA
2024 BMW M2 G87 6spd MT 2025 Ford Bronco
No changes, they fit fine
kdr2824
Kris
Austin, TX
2025 Bronco OBX
Thanks. I just realized that it is not the wheels, but the include TPMS that is not compatible. They changed the frequency for 2025.
MNBigfoot
MN
I am considering ordering these wheels for my 2025 Bronco Outer Banks.
https://www.ford.com/product/20212024-bronco-17-x-85-wheel-kit-dyno-gray-p2804306520
However, the website says that they fit 21-24 models and when I enter my vehicle it says they are not compatible. My understanding is that nothing has changes from 2024-2025. Can someone confirm?
Just keep in mind, that if you ever intend to go with bigger tires you may need different backspacing to eliminate rub. Sasquatch rims have 30mm off-set the rest have 55 (like the ones you posted).
Ducati1098
Somewhat related useless information...I know my 2026, the wheel stud torque is 150Lbs/ft now and my 2024 was 100.
Did they install larger studs in 2026? Or 2025?? 🤷🏻
Nothing has changed.
100 for regular broncos, 150 for raptors.
KreeHBronco
Kevin
Bay area California
2026 Badland 4-dr Manual
One change for 2026, at least for the Badlands non-SAS is the wheel offset changed from +55 to +40. They also installed the large fender flair on my non-SAS even with the 33" tires.
