What offset
Cgybronc
Canada
'20 F350 9"-38s/'15 F350 8"-37s/'10 GT500"stock"
The wheels I want for my project just went on sale and I’m wondering if 0 or -12 (17x9 wheel) would be best to run a 40x13.50R17 Nitto Trail Grappler. My setup is 3” Icon lift w/ 3” body lift on a Wildtrak.
Mikey1287
22 Bronco, 72 Mach, 03 Mach, 69 Mach, 08 Harley
Can't wait to see photos of this :ROFLMAO:
Bikeric
Tulsa
2022 Badlands LUX on 37's
Have you also done the JKS Max Clearance kit? No clue on what wheel offset you will need.
SS Bronco
Shayne
Loomis CA
2021 Bronco , F600, F5, LJ20
I have similar set up. Test fitted 40’s on 0 off set wheels, seamed to fit fine. Did have to trim back my rock sliders 1 inch to avoid contact. Ended up with staying with 37x13.5.
Cgybronc
Canada
I’m going to cut the front bracket off as close as I can to the body mount. There’s a vid of this set up on YouTube but the vendors a little light on details unfortunately.
Cgybronc
Canada
I have aftermarket tube steps on mine that don’t go nearly that far forward as the sliders.
you couldn’t tell me how much poke you had with 0 or better yet a picture?
SS Bronco
Shayne
Loomis CA
I have aftermarket tube stepson on mine that don’t go nearly that far forward as the sliders.
This is 17x9 RTR wheels O
37x13.5x17 Coopers
Sasquatch flares
Ford Bronco What offset 2D5C0C21-5A48-44A5-946A-E293C916C853
Ford Bronco What offset 59268B45-B1ED-4045-A828-C317903B5EA8
JT58Bronc
JT
Fl
Wow, now that will be a cool rig with the lift and those big tires.
Cgybronc
Canada
Turns out the only ones I could get on sale were -12mm so thats what I went with. Hopefully it works out.
Swain
Doug
Chilliwack BC
2011 Ford Raptor with a 2 & 4 broncos on order
Have you had a chance to get the 40’s mounted yet. I am sure that I am not the only one who would like to see some pictures.
Cgybronc
Canada
Unfortunately no, those ranger cab bolts were on back order in Canada and they just showed up this week.
Update on wheels though, the -12mm offset i ordered they only had 3 in stock and couldn’t find a 4th so I had to change things up. I ended up with a 17x9 0mm offset so that should keep things tucked underneath a bit better.
I’m hoping to get started on this project this coming week. I doubt I’ll get as far as fabing up bumper brackets but I’ll see if I can get pics of both lifts in minus the bumpers by weeks end.
