What is this on screen Notice?
BroncoKong Jr.
Andrew
Is yours a daily driver or does it sit for a few days in between?
Our was sitting for a while and I did remember a couple afternoons of work that had doors open until the lights timed out.
Couldn't drive it for a few days so that may be it
ksdon
kansas
mini4mw
W
Atlanta
Tundra
Adoptwithme
Oh
Honda Pilot
Just got this same notice. Have you gotten any answers?
DoubleD
Doug
Crown Point, Indiana
Chevy
Same screen popped up on ours today also. Last week we had the “Service charging system soon” warning light come on twice for about a minute but then it went off on its own
lilfergy
Jennifer
Kansas City MO
2014 Ford C-Max energi
It does not matter if I drive 3 minutes or 20 minutes when I turn bronco off this is the message I get. I also noticed my int lights don't work unless bronco is running? According to the gages my charging system shows 14.2 v.
anyone have any luck figuring this out?
Bronco cat
Carl
Morgantown wv
‘20 Explorer ST, ‘19 GT350, ‘21 Bronco Sport
I know these things and most new cars are battery hogs. My bronco sat for about two weeks and went into low power mode. As an fyi I typically throw mine on a trickle charger every so often to top off the battery because I don’t drive it as much as it needs.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hello, Jennifer. Could you please send us a DM with your VIN and dealership information? I'd be happy to look into how I can assist you on my end.
lilfergy
Jennifer
Kansas City MO
I don’t know how to DM on here.
LAN02
Luke
Maryland
Jeep Wrangler, Mustang GT
For those viewing this thread in the future facing the same issue. Drive it to charge it up, If the screen continues to display this message when you turn the bronco off even after a long drive. Try resetting the battery management system by turning accessory mode on (engine off), then Flashing the high beams 5 times, then pressing the break pedal 3 times. Wait a few seconds to a minute and you will see the red battery icon flash on your dash which indicates you have successfully reset the system. After this, it shouldn’t continue to display that message when you power off.
SuperDave150
Lubbock, TX
Ford F-150, Ford Edge
@Ford Motor Company
i got the “System off to save battery“ message today on my 2023 OBX with Advanced 4WD. (It had been parked for about 5 days)
I noticed that the transfer case mode had switched itself from 4A (which I always leave it in during snowy weather) into 2H.
While this isn’t a big deal as a daily driver, it would be catastrophic if I were flat towing - for the transfer case to shift itself back to 2H in the event of low voltage, etc.!!! That would certainly explain some “mysterious“ contested transfer case and/or transmission failures when flat towing (recreational towing).
dgorsett
colorado
F250, Mustang, Explorer
@Ford Motor Company
Interesting, good observation
Theherofails
Thomas
Phoenix
Ford Bronco What is this on screen Notice? 1705191266544
I track all vehicle stats provided by FordPass via third party software for my smart home and its common to see the Bronco drop down to about ~12v when sitting for a while, but the truck will start disabling "always on" sensors and systems to drop battery usage drastically once you get to the point of seeing the error message in question.
You have to translate percentages to voltage to understand my chart.. This is from Dec 1 to 31st. My smart home automatically does the translation for me but it doesn't show up in the graph.
100% is ~14v, about 75% is the sweet spot (12.25V). I do not drive the Bronco much as it is a second vehicle and you can see that in the chart.
FYI, the really high readings are from FordPass reporting the voltage coming off the alternator while running. Normal range is about 13.8v to 11.9v before my Bronco will go into long term sleep mode..
Ford Bronco What is this on screen Notice? 1705191965968
This is where it's sitting today after not driving it since last weekend.. You can see the voltage does drop over time.
I hope this data helps some how. Just thought I'd share what I've collected.
